Probe Basic Transition from Axis
- OldSQL
19 Dec 2023 00:13 #288530
by OldSQL
Probe Basic Transition from Axis was created by OldSQL
Hello everyone, I'm a beginner in Probe Basic and I'm trying to transition from an Axis configuration to PB with ATC included, and I'm having some issues that I can't solve due to lack of experience. At the moment, I can open PB, if in my INI file the hal files (io.hal, spindle.hal, postgui.hal) are commented out. When I have not these file calls in the INI config, I can open PB, but it says I have to turn off EStop to be able to start the machine. I didn't have this problem with Axis. I've already reversed the signal call and it continues. Can anyone help me?Attached is my configuration.
- Lcvette
- Thank you received: 784
19 Dec 2023 01:25 #288534
by Lcvette
Replied by Lcvette on topic Probe Basic Transition from Axis
You need all of those files for pb, use the config conversion document in the sticky section.
forum.linuxcnc.org/qtpyvcp/48401-py3-pro...version-doc-lcnc-2-9
- OldSQL
19 Dec 2023 02:07 #288535
by OldSQL
Replied by OldSQL on topic Probe Basic Transition from Axis
Yes, I have already followed this guide and successfully started and configured part of the Probe Basic. Now, I have this problem: is there a way to resolve it without losing all the progress I've made?
- Lcvette
19 Dec 2023 02:25 #288536
by Lcvette
Did you press estop on the bottom left of the screen?
- OldSQL
19 Dec 2023 10:10 #288564
by OldSQL
Yes, and it shows the same message.
- Unlogic
- Thank you received: 128
19 Dec 2023 12:51 #288580
by Unlogic
Replied by Unlogic on topic Probe Basic Transition from Axis
When I migrated from Axis to Probe Basic I encountered something similar due to some e-stop signals in my custom.hal overlapping with the existing e-stop signals in Probe Basic.
I renamed my e-stop related signals to solve the problem.
- OldSQL
19 Dec 2023 13:49 #288583
by OldSQL
Okay, do you suggest renaming in the main .hal file or in the halib?
- Unlogic
19 Dec 2023 14:32 #288584
by Unlogic
Go through all the hal files and check which ones that refer to e-stop, also check out my thread in this forum section regarding the initialization problems I had which forced me to load my customs changes after the probe basic post gui file.
- OldSQL
19 Dec 2023 15:34 #288590
by OldSQL
- OldSQL
21 Dec 2023 09:42 #288742
by OldSQL
What is the best recommendation to redo the entire configuration step by step. Any complements to the existing tutorial?
Moderators: KCJ, Lcvette
Time to create page: 2.899 seconds
