Probe Basic Transition from Axis
2 years 10 months ago #288945 by rodw
Just keep commenting out pins until it opens and review for the correct pin names.
Linuxcnc always tells you the file and line number the error is on.
Typographic errors like this  are not linuxcnc or probe basic bugs. They are on you.
The following user(s) said Thank You: OldSQL
2 years 10 months ago #288968 by Unlogic
I ran into this very same error message, solved it by moving the initialization of my custom hal code after the postgui stuff for probe basic.
2 years 10 months ago #289014 by OldSQL
You run PB with ATC?
2 years 10 months ago #289046 by Unlogic
Nope, manual tool changes.
2 years 10 months ago #289072 by OldSQL
To do ATC config, I need to create a XYZA config or just XYZ and then attribute the motor control to an ATC hal without joint 4?
2 years 10 months ago #289098 by OldSQL
Well, now i can run all the probe basic without any problem, however, i cant home my atc.
Can anyone help me by checking what is missing in my files ?
File Name: TrustepOmn...12-26.gz
File Size:53.92 KB
Moderators: KCJ, Lcvette
Time to create page: 0.431 seconds
