Probe Basic Transition from Axis
2 years 10 months ago #288915 by OldSQL
I created the Axis configuration in Pncconf, and everything was working right. Then when transitioning to PB, I created the HAL files by writing them. I might have done something wrong or missed a call instruction.
2 years 10 months ago #288916 by OldSQL
When I made the initial INI edit following the guide's post, I managed to open PB and home the axes. However, when I started delving into more changes, including all the necessary files for the ATC's operation and configuration, this issue emerged.
2 years 10 months ago #288917 by dpslwk
seem you have moved all the HAL around trying split into multiple files??
and in doing so you have commented out the command that are setting up the mesa card (realtimecomponents.hal)
The following user(s) said Thank You: OldSQL
2 years 10 months ago #288925 by OldSQL
  You were right. I've changed everything, and now Probe Basic (PB) is working. However, I'm having trouble powering on the machine as before, and I've already looked into the E-Stop connection issue. When I make changes and press X-view, for example, the following error appears.
2 years 10 months ago - 2 years 10 months ago #288927 by OldSQL
File Name: TrustepOmn...-23-2.gz
File Size:50.49 KB
This is now my config. I already can open it. But it looks like there are something missing.
Last edit: 2 years 10 months ago by OldSQL.
2 years 10 months ago #288940 by OldSQL
If I configure it with only 1 hal file, will it be better?
Isn't this a Probe Basic bug?
Moderators: KCJ, Lcvette
Time to create page: 0.479 seconds
