Probe Basic Stable error
- ncf250sd
27 Jan 2026 03:09 #341982
by ncf250sd
Replied by ncf250sd on topic Probe Basic Stable error
My start position was well inside of the .3, it’s pretty small stock. All the outside corners behave the same, I didn’t check the inside.
- ncf250sd
27 Jan 2026 03:10 #341983
by ncf250sd
Yes, I have the probe tip dia set
- Lcvette
- Thank you received: 782
27 Jan 2026 03:17 #341984
by Lcvette
Replied by Lcvette on topic Probe Basic Stable error
.3 is from the starting poin. If you're .15 from the edge it's only going to move .15 past the edge. Step off should be adjusted until you comfortably clear the edges.
If you're still having issues you can check your car file to see if your are correctly updating.
Moderators: KCJ, Lcvette
Time to create page: 0.353 seconds
