qtvcp issues
07 Dec 2018 10:05 #121995 by cmorley
Replied by cmorley on topic qtvcp issues
hmm I see my probe screen is not exactly the same as your posted pic.
I pulled again without change - did you push that design ?
Chris M
  • auto-mation-assist
  • auto-mation-assist's Avatar
  • Platinum Member
  • Platinum Member
08 Dec 2018 02:13 #122028 by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
I will check to make sure. I did do a pull after I pushed and it looked ok to me then but there is always a possibility that I overlooked some thing. I will check later today and correct it if I locate the issue you are seeing.
I was finishing up some jogging code for all three jog modes I have along with their individual slow/fast modes for each and I have not found a separate action for setting the angular jog rate. I did find separate action and status for the linear and angular increments. So that leads to me asking if the jog rates for linear and angular jogging use the same rate action.
08 Dec 2018 02:53 #122030 by cmorley
There are 4 rog rate setting commands:
ACTION.SET_JOG_RATE( rate):
ACTION.SET_JOG_RATE_ANGULAR(rate):
ACTION.SET_JOG_INCR(incr, text):
ACTION.SET_JOG_INCR_ANGULAR(inc, text)
there jog rate will always be in machine units
Chris M
  • Platinum Member
  • Platinum Member
08 Dec 2018 04:59 #122037 by auto-mation-assist
Ok I was missing the Angular rate one.
I’m not sure what the 'text' is used for in the increments, Just been setting it at 0 (zero) for now and everything works fine as far as incremental movement for all 16 of my increments for linear and the 16 for angular movement. Continuous jog has also been checked out for the x1mill gui.
All jogging required values and info for labelling the buttons and setting true state values for buttons is derived from the the .ini file. I’m using lists to handle configuration data.
  • Platinum Member
  • Platinum Member
08 Dec 2018 05:10 #122038 by auto-mation-assist
Chris,
I have downloaded what I have on github and the files for the gui in the, "x1Mill_branch/configs/sim/x1Mill/versa_probe/" folder are the latest and when loaded into the designer show what is in the picture below.
I that is not what your seeing then I likely need to push them somewhere else because the pulls from you may be looking at a different location that has older files.
This is the picture of the .ui file that I pushed three days ago to the above mentioned location. It came from there about thirty minutes ago.
  • Platinum Member
  • Platinum Member
08 Dec 2018 05:19 #122040 by auto-mation-assist
I just did a pull it shows that you are behind since you do not have the tool measure button and the history button. I will look at where this came from and replace it.
  • Platinum Member
  • Platinum Member
08 Dec 2018 05:45 #122041 by auto-mation-assist
Ok I found the file you were using and replace it with the latest one.
I think you were pulling from:
x1Mill_branch/configs/sim/x1Mill/x1Probing/
And I was updating:
I have made them both the same and will delete the one your not going to use.
08 Dec 2018 05:47 #122042 by cmorley
And I was updating:
Ahh I see.
Ok great ill pull again
08 Dec 2018 05:51 #122043 by cmorley
text is used by other widgets (ie status_label) to display what increment is currently active.
It is used so you can add units to the display.
Chris M
The following user(s) said Thank You: auto-mation-assist
  • Platinum Member
  • Platinum Member
09 Dec 2018 01:08 #122089 by auto-mation-assist
I was moving around some functions in my handler and then checking out to make sure everything was still ok. And it was, except my jog rate display was now showing 360 which is strange because I have nothing that would make it set that high on my sliders. There are likely two problems, it should have entered my settings and 2nd where does the 360 come from. So first the source of the 360 which reminds my of a bad angle reset to zero at the 358.99999999 point.
Anyway to find the source of the 360 jog rate I did the below about as early as I can in my handler file:
print "line_251 STATUS.get_jograte", STATUS.get_jograte()
print "line_252 STATUS.get_jograte_angular ", STATUS.get_jograte_angular()
This resulted in this:
line_251 STATUS.get_jograte 60.0
line_252 STATUS.get_jograte_angular 360
I do believe that these should both be 0 (zero) at start up without the need to set them to zero .
Time to create page: 1.618 seconds
