- Thank you received: 81
qtvcp issues
- auto-mation-assist
I have downloaded what I have on github and the files for the gui in the, "x1Mill_branch/configs/sim/x1Mill/versa_probe/" folder are the latest and when loaded into the designer show what is in the picture below.
I that is not what your seeing then I likely need to push them somewhere else because the pulls from you may be looking at a different location that has older files.
This is the picture of the .ui file that I pushed three days ago to the above mentioned location. It came from there about thirty minutes ago.
I think you were pulling from:
x1Mill_branch/configs/sim/x1Mill/x1Probing/
And I was updating:
I have made them both the same and will delete the one your not going to use.
- Thank you received: 2181
Ahh I see.auto-mation-assist wrote: Ok I found the file you were using and replace it with the latest one.
And I was updating:
Ok great ill pull again
auto-mation-assist wrote: Ok I was missing the Angular rate one.
I’m not sure what the 'text' is used for in the increments, Just been setting it at 0 (zero) for now and everything works fine as far as incremental movement for all 16 of my increments for linear and the 16 for angular movement. Continuous jog has also been checked out for the x1mill gui.
All jogging required values and info for labelling the buttons and setting true state values for buttons is derived from the the .ini file. I’m using lists to handle configuration data.
text is used by other widgets (ie status_label) to display what increment is currently active.
It is used so you can add units to the display.
Chris M
Anyway to find the source of the 360 jog rate I did the below about as early as I can in my handler file:
print "line_251 STATUS.get_jograte", STATUS.get_jograte()
print "line_252 STATUS.get_jograte_angular ", STATUS.get_jograte_angular()
This resulted in this:
line_251 STATUS.get_jograte 60.0
line_252 STATUS.get_jograte_angular 360
I do believe that these should both be 0 (zero) at start up without the need to set them to zero .
