- Thank you received: 267
qtvcp issues
- KCJ
7 years 10 months ago #122769
by KCJ
Replied by KCJ on topic qtvcp issues
Very nice looking screen you have there, fantastic work!
Kurt
Kurt
The following user(s) said Thank You: auto-mation-assist
- auto-mation-assist
- Thank you received: 81
7 years 10 months ago #122771
by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
while looking at file hal_glib.py in lines 204 and 205 it appears that line 205 may have a spelling error.
204 self.current_jog_rate = 15
205 self.current_angular_jog_tate = 360
But jog_tate appears in five locations in the file.
7 years 10 months ago - 7 years 10 months ago #122773
In ref to my prior post that mentioned, "I did notice that the second spindle does not show up in halui."
I was able to do further research on this and found a note by andypugh that there are two places that the number of spindles had to be entered in the .ini file. I had only done one. After adding a second one in [TRAJ]SPINDLES as SPINDLES = 2 the second spindle now shows up in halui.
My two entries in the .ini file are thus:
[EMCMOT]NUM_SPINDLES = 2
[TRAJ]SPINDLES=2
The first will show up in hal show under 'spindle' while the second will show up in 'halui'.
In my hal file I have the below which handles the first one listed:
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[EMCMOT]NUM_JOINTS num_spindles=[EMCMOT]NUM_SPINDLES
[TRAJ]SPINDLES=2
Last edit: 7 years 10 months ago by auto-mation-assist.
7 years 10 months ago #122775
Replied by andypugh on topic qtvcp issues
You _could_ keep it in only one place:
The reason for this situation (which I admit looks like carelessness on my part) is that "motion" (ie, motmod) is a real-time component and has no access to the file system. So all parameters have to be passed to it on the command line when it is loaded.
Other parts of the system (such as halui) _do_ have file system access and are able to access the INI file.
The complication here is that your HAL file is passing command-line parameters to motion from the INI file, so it looks like redundancy, but isn't really.
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[EMCMOT]NUM_JOINTS num_spindles=[TRAJ]NUM_SPINDLES
7 years 10 months ago - 7 years 10 months ago #122779
I have been playing with some spindle commands for my A axis spindle mode as below and they appear to generate the correct action as indicated by hal status and hal show.
def scrb_spindle_1_rpm_setValue(self,value):
spin_1_rps = float(value)/10000
self.cmnd.spindleoverride(spin_1_rps,1)
self.w.lab_spindle_1_rpm.setText(str(self.w.scrb_spindle_1_rpm.value()/100))
def pbtn_spindle_1_forward_toggle(self):
self.cmnd.spindle(1,400,1) # dir/speed/spindle numb
def pbtn_spindle_1_stop_toggle(self):
self.cmnd.spindle(0,1) # stop/spindle numb
def pbtn_spindle_1_reverse_toggle(self):
self.cmnd.spindle(-1,400,1) # dir/speed/spindle numb
I have not fully configured the system to actually get motor motion since the switching required to change from normal A axis indexer type configuration to spindle configuration requires qtvcp to be able to handle 4 joints/axis instead of the 3. Pushing buttons related to Axis movement just gives verbal messages mentioning 3 axis. I hope that this can be overcome without to much difficulty.
Qtvcp does not generate an error message when the number of joints/axis are more than it can handle.
7 years 10 months ago #122807
I poked around in various files and all indications were that my axis/joint letters and numbers were correct. So I took a different approach and found my answer.
It turns out that the reason my A axis was not responding to jogging commands was this simple .INI entry: LOCKING_INDEXER = 1. Upon changing that to LOCKING_INDEXER = 0 qtvcp no longer gives me verbal warnings and the DRO indicates that there is movement.
Axis/joint letters and numbers generated in various files seems to indicate that QTvcp may be able to support 9 axis/joints. Is this a correct assumption or will there need to be updates to allow at least 5 axis/joints?
Time to create page: 1.637 seconds
