qtvcp issues
  • auto-mation-assist
  • Platinum Member
  • Platinum Member
8 years 2 weeks ago - 8 years 2 weeks ago #118919 by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
I used the Linuxcnc-Controller area (StatusStacked) and hoping that there would be no issues in getting some of my buttons to open up a particular page in a particular named stack by "stack name" and "index number".
If I need to I can change them to the QT Containers Stacked Widget type.
My stacked page names (changed from all being: ("statusstacked") are as below with each stack now starting at index 0.
stacked_frame_0
stacked_frame_1
stacked_frame_2
stacked_frame_3
Last edit: 8 years 2 weeks ago by auto-mation-assist.
8 years 2 weeks ago #118922 by cmorley
Replied by cmorley on topic qtvcp issues
Yes I think you'll need to change them. StatusStack widgets are specifically used to switch automatically to linuxcnc mode state.
I just pushed some more work on action buttons so they can run python code.
So if you want to switch a stackwidget or a tab widget with a button press...
add a default stackwidget and fill the pages as you like. name it something helpful - say stack_frame_0
add enough action buttons to cover all the pages you want to select.
select python_command_action on each action button.
under the false_python_cmd_string add this:
INSTANCE.stack_frame_0.setCurrentIndex(0)
but on each button use a different page index number. index start at zero and go up
That should do it.
Chris M
The following user(s) said Thank You: auto-mation-assist
8 years 2 weeks ago #118923 by cmorley
If you want to test this without changing the stack widgets you have you can.
It's just when linuxcnc changes mode they will change too.
Chris M
8 years 2 weeks ago #118929 by cmorley
I changed my mind a bit and push more work that changes where the python commands are added. You'll find the python command properties under indicated_buttons title ( its still using action buttons)
Also for a non checkable button you's use the true_python_cmd_string now
Hope that wasn't too confusing...
Chris M
  • Platinum Member
  • Platinum Member
8 years 2 weeks ago #118970 by auto-mation-assist
I'm somewhat confused in building a handler file and still exploring the available samples with the qt5vcp_py2 branch. In working with glade in the past I could see the signals and name them, but how do I find them in qtvcp? I always liked to make a signals list in a .txt file to help with coding.
I'm hoping that I will be able to display the gui soon but right now loading fails before that point. This really not surprising since a proper handler as not been built yet.
Debug gives me lots of output before shutting things down as in the few lines shown below.
emc/task/emctask.cc 396: interp_error: File not open
File not open
Then lots more debug messages and finally where it stops:
[QTvcp.QTVCP.QT_MAKEPINS][DEBUG] HAL-ified instance found: abtn_override_feed_rate (qt_makepins.py:56)
[QTvcp.QTVCP.QT_MAKEPINS][DEBUG] HAL-ified instance found: btn_jog_method (qt_makepins.py:56)
[QTvcp.QTVCP.QT_MAKEPINS][DEBUG] HAL-ified instance found: slider_jog_slow_rate (qt_makepins.py:56)
It also reporting that it needs a change here:
[QtDesigner.QTVCP.QT_ISTAT][WARNING] Invalid message configuration (missing boldtext) in INI File [DISPLAY] sectioN (qt_istat.py:143)
I will do another pull and continue to work on this.
8 years 2 weeks ago #118975 by cmorley
As a test try this:
save your designer screen in configs/sim/qtvcp_screens as tester.ui
start linuxcnc and select :
sample configs / sim / qtvcp_screens / tester
That should load your screen as a sim- it also displays tons of debug lines in the terminal
Chris M
Time to create page: 1.076 seconds
