Sample Qtvcp Screens
3 years 9 months ago #263042 by rodw
Replied by rodw on topic Sample Qtvcp Screens
Actually @1536 x 834, the squashed text eappears to be in the spindle group. Do I have a font missing?
To me it looks like the left edge should align with the jogging group and shrinking the sliders
3 years 9 months ago #263057 by hottabich
Replied by hottabich on topic Sample Qtvcp Screens
You can go to the designer and fix the size for your monitor. Or fix it. And you don't have to delete anything. Everything works. I am attaching the corrected version.
3 years 9 months ago #263064 by rodw
Well, after installing a couple of fonts
BebasKai.otf
BebasKai.ttf
Lato-Heavy.ttf
and tweaking the spindle up and down button text in QT DEsigner, I solved most of my problems but I have an issue with the jogging increments I don't know how to solve:
Further help appreciated :)
3 years 9 months ago #263073 by MarkoPolo
Replied by MarkoPolo on topic Sample Qtvcp Screens
Hi Chris
It's a good idea to place the settings sections in the qspiters, I also thought about it and I've already done some tests, you could also make the lower sections so that they are set in a certain range.
After turning on qtdragon to full screen and setting the sizes of individual sections, is it possible to save such a layout to restore the layout after restarting?
If you can, share the modified qtdragon.ui file
3 years 9 months ago - 3 years 9 months ago #263081 by hottabich
You can go to the designer and fix the size for your monitor. Or fix it. And you don't have to delete anything. Everything works. I am attaching the corrected version.Well, after installing a couple of fontsBebasKai.otf BebasKai.ttf Lato-Heavy.ttfand tweaking the spindle up and down button text in QT DEsigner, I solved most of my problems but I have an issue with the jogging increments I don't know how to solve:Further help appreciated :)  Thank you for your attention. I fixed the speed increment bug. There was no mark in the status_label. Problems with sizes still arise because there is no hiding of system panels. Judging by the screenshot, you are using Pop OS?
Last edit: 3 years 9 months ago by hottabich.
3 years 9 months ago #263083 by tommylight
Replied by tommylight on topic Sample Qtvcp Screens
Nope, not Pop OS, at least not the default appearance.
Looks like some ChromeBook versions of Linux.
Time to create page: 0.254 seconds
