Sample Qtvcp Screens
3 years 9 months ago #263085 by rodw
Replied by rodw on topic Sample Qtvcp Screens
Hmm, Thanks, that made no difference here. I dd go into designer and its the same as your screendump.
Yeh Tommy is right, I run sims on my Chromebook which lets you install Debian Bullseye on it.
I have been having troubles with it running wayland but finally have a workaround for that by putting this in muy .profile
export PYOPENGL_PLATFORM=x11
Bedtime here.
I may see if i can get this on a machine tomorrow.
3 years 9 months ago #263101 by cmorley
Replied by cmorley on topic Sample Qtvcp Screens
Hi Chris
It's a good idea to place the settings sections in the qspiters, I also thought about it and I've already done some tests, you could also make the lower sections so that they are set in a certain range.
After turning on qtdragon to full screen and setting the sizes of individual sections, is it possible to save such a layout to restore the layout after restarting?
If you can, share the modified qtdragon.ui file
I'll start a new thread for this.
3 years 3 weeks ago #282732 by udoS
Replied by udoS on topic Sample Qtvcp Screens
Hi to ALL.
I've set up the QtDragon HD with z compensation; now I try to work with touch plate and tool sensor but I'm not clear as how they are working.
First Tool-Sensor: what should happen if my Code says T2 M6; It should go to tool-change position, I change the tool, hit OK, then ... ?
Can anyone help on that?
3 years 3 weeks ago #282746 by cmorley
please make a separate topic (under qtvcp) for this question.
This is for showing off new screen ideas.
Thank you.
Time to create page: 0.331 seconds
