Hi Chris
Thanks for your help on this
It may have been the PYQTDESIGNERPATH. I went through another thread that I found that said to run export PYQTDESIGNERPATH='/path/to/plugin/directory/'
I took the text too literally and kept the ' marks
I just ran export PYQTDESIGNERPATH=/usr/lib/x86_64-linux-gnu/qt5/plugins
And now I get the following when I run designer (and still no widgets) (I get the same if the libpyqt5_py2.so is named this or libpyqt5_py2.bak)
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
libpng warning: iCCP: known incorrect sRGB profile
qt5ct: D-Bus system tray: no
When I close QT Designer I get an extra error
QXcbConnection: XCB error: 3 (BadWindow), sequence: 709, resource id: 54538204, major code: 40 (TranslateCoords), minor code: 0
Maybe I should try uninstalling all QT related packages and then run Phil's script again
Cheers
Bruce
