Installing QtVCP
5 years 8 months ago #197999 by robertspark
Replied by robertspark on topic Installing QtVCP
Thanks Phil
I get the feeling I am so close.
('Qtvcp python plugin found:', '/home/rob/.designer/plugins/python/qtvcp_plugin.py')
[QtDesigner][INFO] Logging to "/home/rob/qtdesigner.log" (logger.py:100)
[QtDesigner.QTVCP.WIDGETS.MDI_HISTORY][DEBUG] MDI History file created: /home/rob/.axis_mdi_history (mdi_history.py:72)
ICE default IO error handler doing an exit(), pid = 6058, errno = 32
5 years 8 months ago #198001 by robertspark
I did a restart (when in doubt, pull the plug out :) and it seems to fire up with all of the linuxcnc bits
The following messages when starting from terminal:
rob@RobsCNC:~$ designer -qt=5
('Qtvcp python plugin found:', '/home/rob/.designer/plugins/python/qtvcp_plugin.pyc')
tool_mmap_user(): file open fail: No such file or directory
tool_mmap_user(): no mmap file,continuing
mmap tool data not available, continuing emc/usr_intf/axis/extensions/emcmodule.cc
[QtDesigner.QT5_GRAPHICS][WARNING] linuxcnc staus failed, Assuming linuxcnc is not running so using fake status for a XYZ machine (qt5_graphics.py:214)
5 years 8 months ago - 5 years 8 months ago #198091 by phillc54
Replied by phillc54 on topic Installing QtVCP
robertspark wrote: I did a restart (when in doubt, pull the plug out :) and it seems to fire up with all of the linuxcnc bits
I seem to recall Chris mentioning this somewhere recently but I cannot seem to find it, hopefully he will chime in.
EDIT: I found the issue: github.com/LinuxCNC/linuxcnc/issues/1067
Last edit: 5 years 8 months ago by phillc54.
5 years 8 months ago #198111 by cmorley
Replied by cmorley on topic Installing QtVCP
This printout is expected now - This is not an actual error.
5 years 8 months ago #198241 by phillc54
Script has been updated with some files required for other distributions and should now work for both python2 and python3 installations.
The following user(s) said Thank You: robertspark
5 years 8 months ago #198503 by phillc54
robertspark wrote:
libpyqt5_py2.so.tar.gz not found in /usr/lib/python2.7/dist-packages/qtvcp/designer/x86_64/qt5.11/
I can confirm that there is no qt5.11 folder within /usr/lib/python2.7/dist-packages/qtvcp/designer/x86_64/
This is also fixed and now available on buildbot installs.
Time to create page: 0.366 seconds
