Installing QtVCP
5 years 2 weeks ago - 5 years 2 weeks ago #223239 by phillc54
Replied by phillc54 on topic Installing QtVCP
This error "ImportError: No module named PyQt5" indicates the the script didn't run correctly.
What version of LinuxCNC are you using?
Base directory means the name of the sub directory in your home directory that you have install a run in place version of LinuxCNC, that is usually linuxcnc-dev.
If you are using LinuxCNC 2.8 then there is an udated script, I have attached a copy here.
File Name: install_script_28.txt
File Size:4.42 KB
EDIT: I have update the first page to add the 2.8 script download.
Last edit: 5 years 2 weeks ago by phillc54.
5 years 2 weeks ago #223245 by Muzzer
Replied by Muzzer on topic Installing QtVCP
Thanks - yes I'm on 2.8, so will run the updated script.
Many thanks!
5 years 2 weeks ago #223295 by Muzzer
Well that was lightning quick but it's still complaining about various missing python-pyqt5 content. Do I need to point it at some additional stuff?
Here's the terminal text attached.
File Name: Qtvcperrorfile.txt
File Size:3.21 KB
5 years 2 weeks ago #223326 by phillc54
What Linux disto are you using?
5 years 2 weeks ago #223327 by Muzzer
Mint 20 - and LinuxCNC 2.8:
System:    Kernel: 5.10.0-8-rt-amd64 x86_64 bits: 64 compiler: N/A Desktop: Cinnamon 5.0.5
           wm: muffin dm: LightDM Distro: Linux Mint 20.2 Uma base: Ubuntu 20.04 focal
5 years 2 weeks ago #223328 by phillc54
have no clue ...
Is Qt5 installed?
Is python2.x installed?
Try runnining Synaptic and see if python-pyqt5 can be installed from there of if it gives a better message.
Time to create page: 0.160 seconds
