- Thank you received: 2100
Can you check the first post and see if that looks OK.hottabich wrote: Thanks for attention! Add to the instructions, run in the terminal. For people like me. Everything settled well and bistro. Thank you for your work.
Qtvcp is only in the docs for 2.8 and master.bbsr_5a wrote: on what OS will this work
there are peaple using varios combinations
i woudt like to see a warning that tels please update to 2.x First
There is a different version of libpyqt5_py2.so for qt5.5, qt5.7 & qt5.9 and that is handled by the installer script.isent there also a depencies clinch as it installs not the os related QT like 5.4 against 5.8
