Сustomization QTvcp
5 years 5 months ago - 5 years 5 months ago #209880 by hottabich
Replied by hottabich on topic Сustomization QTvcp
Almost like that. For now dialogue window is missing an option to set up safe height to start from line execution. Dialog dro label x, y, z.... coordinate line number. Is it possible to have such functionality at LinuxCNC? Thanks in advance
Last edit: 5 years 5 months ago by hottabich.
5 years 5 months ago #209929 by cmorley
Replied by cmorley on topic Сustomization QTvcp
What is the difference between the xyz settings and the safe height setting?
Typically one would manually jog the machine into position before restarting the program.
5 years 5 months ago #210040 by hottabich
At the moment there is no way to start work from scratch of the workpiece from the selected line. G54 (x0,y0,z0) Start line number, lifting the cutter to a given safe height, starting the spindle, pause for 5 seconds, the tool goes to the coordinates of the selected line and lowers along the z, work is in progress. This is relevant after shutdown of the scheduled and emergency machine. Thanks for attention!
5 years 1 month ago - 5 years 1 month ago #220229 by hottabich
[justify]Hello! I want to add to the woodpecker from QtDragon hd master apply_stylesheetCombo. Please help to register correct signal slot. Thanks![/justify]
Last edit: 5 years 1 month ago by hottabich.
5 years 1 month ago - 5 years 1 month ago #220237 by cmorley
Try this (untested)
In designer change the slot name from 'cmb_stylesheet_curentindex()' to 'apply_stylesheet_clicked(int)'
change function in handler file to:
def apply_stylesheet_clicked(self, index):     self.styleeditor.styleSheetCombo.setCurrentIndex(index)     self.styleeditor.on_applyButton_clicked()
Last edit: 5 years 1 month ago by cmorley.
5 years 1 month ago - 5 years 1 month ago #220244 by hottabich
Thank you, now it's switching the stylesheet. But also default stylesheet doesn't apply. (please see screenshot)
Stylesheet .gss files are located in config directory. Linux CNC 2.8.2
Time to create page: 0.676 seconds
