Сustomization QTvcp
5 years 1 month ago #220247 by cmorley
Replied by cmorley on topic Сustomization QTvcp
See if this helps:
def apply_stylesheet_clicked(self, index):     self.styleeditor.styleSheetCombo.setCurrentIndex(index)     self.styleeditor.selectionChanged(index)     self.styleeditor.on_applyButton_clicked()
5 years 1 month ago - 5 years 1 month ago #220250 by hottabich
Replied by hottabich on topic Сustomization QTvcp
Cathed an error.
Fixed, and now it works
        if self.w.cmb_stylesheet.currentText() == "As Loaded": return
Thank you so much!
Last edit: 5 years 1 month ago by hottabich.
5 years 1 month ago #220251 by cmorley
Excellent!
5 years 3 days ago #224655 by hottabich
Hello! How to register so that when choosing tab_mdi TabWidget interface went to mdi_mode. Thanks!
5 years 2 days ago #224662 by cmorley
You can add a signal in designer to tab_widget that is sent when the tab changes.
currentChanged(int) pobably would do what you want.
5 years 2 days ago - 5 years 2 days ago #224666 by hottabich
I don't see the sender (tab_mdi) in the constructor.
self.w.main_tab_widget.setCurrentIndex(TAB_MDI)
            self.w.tab_mdi.setChecked(True)
ACTION.SET_MDI_MODE()
        self.w.mdi_mode_button.setChecked(True) I need to somehow link it in the handler. I think so.
Last edit: 5 years 2 days ago by hottabich.
Time to create page: 0.171 seconds
