Сustomization QTvcp
3 years 9 months ago #263221 by hottabich
Replied by hottabich on topic Сustomization QTvcp
I tried, please take a look.  File GitHub sim.qtvcp_screens.woodpecker_hd-5axis.
3 years 9 months ago #263440 by cmorley
Replied by cmorley on topic Сustomization QTvcp
Sorry i was busy at work. I will soon.
3 years 8 months ago #263492 by cmorley
Do you use a compiled RIP version or an installed version of linuxcnc?
If you compile your system, it would be easier to fork linuxcnc into your repository and work from there but we can do it another way:
In your config folder, you will see a folder named 'qtvcp'.
inside that folder you should see 'screens'
Inside the 'screens' folder you should create the woodpecker folder and add all the required files.
ie. ui, handler, images, tool_icons, helpfiles, (fonts?)
The folder you add should use the same base name as the screen code.
You can test it and when it work fine, that is the code I need.
Here is a look at the folders in linuxcnc:
github.com/LinuxCNC/linuxcnc/tree/master/share/qtvcp/screens
you will notice it uses the same pattern qtvcp/screens/<SCREEN_NAME>
This is what we need to do to add it to linuxcnc.
Chris
3 years 8 months ago #263494 by cmorley
3 years 8 months ago #263502 by hottabich
Created a folder as in the screenshot, deleted the previous one. The interface opens but it is not in the examples. What am I doing wrong?
3 years 8 months ago #263527 by cmorley
So that integrates the screen code.
Now u need to add a ssmple configuration in config/sim/woodpecker thatbincludedls the ini, hal etcl files
Time to create page: 3.043 seconds
