Сustomization QTvcp
- hottabich
- Thank you received: 96
10 Apr 2020 08:54 #163460
by hottabich
Сustomization QTvcp was created by hottabich
There is no Max_velocity_override adjustment in the Qtvcp interface. I added a panel. The slider adjusts the speed correctly, but I can’t adjust the percent. Status max_vel_ovr vibran.
Please tell me what is wrong.
- Thank you received: 2181
10 Apr 2020 14:58 #163488
Replied by cmorley on topic Сustomization QTvcp
In Qtvcp (and others screens), max velocity is in absolute units per minute, not percent.
You could build what you want but it would require python programming.
Chtis
Chtis
- Thank you received: 7490
10 Apr 2020 15:30 #163499
Replied by tommylight on topic Сustomization QTvcp
Changed the name? Going for witnes protection?In Qtvcp (and others screens), max velocity is in absolute units per minute, not percent.
Chtis
10 Apr 2020 15:55 #163502
oops -you figured it out!
- hottabich
10 Apr 2020 17:52 - 10 Apr 2020 18:31 #163515
by hottabich
Replied by hottabich on topic Сustomization QTvcp
Can you do something with this? The question is closed. I assigned the necessary speeds to the buttons and everything works. Thanks for the consultation!
Last edit: 10 Apr 2020 18:31 by hottabich.
10 Apr 2020 20:55 #163529
To add a max velocity slider.
add a QSlider with designer called 'mvPercent'
then in your handler file:
def initialized__(self):
self.w.mvPercent.setMaximum(100)
STAT.connect('max-velocity-override-changed', lambda w, data: self.w.mvPercent.setValue((data / INFO.MAX_TRAJ_VELOCITY)*100))
self.w.mvPercent.valueChanged.connect(self.setMVPercentValue)
# GENERAL FUNCTIONS #
def setMVPercentValue(self, value):
ACTION.SET_MAX_VELOCITY_RATE(INFO.MAX_TRAJ_VELOCITY * (value/100.0))
- hottabich
11 Apr 2020 05:04 #163575
by hottabich
Thank you so much! Very good as a basic option. It’s more convenient for me
actual speed value on the button.
- hottabich
13 Apr 2020 11:04 - 13 Apr 2020 11:05 #163862
by hottabich
File ini / TRAJ - NO_FORCE_HOMING = 1. At start, the tool position is the same
as exit, Home_All button green, the interface is active but does not work like that. How to fix please tell me.
Last edit: 13 Apr 2020 11:05 by hottabich.
13 Apr 2020 19:05 #163895
I'm looking into this. I see it complains when you select the MDI line, but I can't find the source of that complaint....
- hottabich
13 Apr 2020 19:46 - 13 Apr 2020 20:12 #163897
by hottabich
At start qtdragon G54 should beat X = 0, Y = 0, Z = 0. Button Home All = All Homed. Homing mode no. Can I do this?
Last edit: 13 Apr 2020 20:12 by hottabich.
Time to create page: 0.155 seconds
