Сustomization QTvcp
- hottabich
- Thank you received: 96
17 Apr 2020 19:32 #164305
by hottabich
Replied by hottabich on topic Сustomization QTvcp
I am using Linux debian 4.9.0-8-rt-amd64 # 1 SMP PREEMPT RT Debian 4.9.130-2 (2018-10-27) x86_64 GNU / Linux. Linuxcnc 2.8-pre 5649. System Language
translated into English no changes. If you disable last_loaded_program all
working.
working.
- hottabich
17 Apr 2020 19:51 - 17 Apr 2020 20:01 #164312
by hottabich
All OK!!! You are the best. Thank you very much.In dialog_widget.py line 532 change to:
if fname and not return_path: if self.PREFS_: self.PREFS_.putpref('last_file_path', fname, str, 'BOOK_KEEPING') ACTION.OPEN_PROGRAM(fname) STATUS.emit('update-machine-log', 'Loaded: ' + fname, 'TIME') return fname
Should store the program name properly
Chris
Last edit: 17 Apr 2020 20:01 by hottabich.
- Thank you received: 2175
17 Apr 2020 20:00 #164314
Replied by cmorley on topic Сustomization QTvcp
Did you load a program using the dialog after the change?
It has to make a difference.
Actually QtDragin is using 'last_file_path' wrong.
'last file path' in preference file is supposed to not have a filename, it is used to preselect the folder when you open the load dialog.
I'll figure out the proper fix soon
- hottabich
17 Apr 2020 20:04 - 17 Apr 2020 20:07 #164315
by hottabich
Sorry, I hastened to answer All OK!!! The question is closed.
Last edit: 17 Apr 2020 20:07 by hottabich.
- hottabich
17 Apr 2020 20:13 #164318
by hottabich
If you can still ask a question. MDITouchy may work in qtdragon or better
delete page. What do you advise?
17 Apr 2020 21:01 #164329
MDITouchy can work in Qtdragon for sure.
You must code a button to run the MDI command though.
In QtTouchy the cycle start HAL pin will run the MDI command as long as the machine is in MDI mode.
You must decide how you would like to run the command
17 Apr 2020 22:18 #164343
I pushed work to linuxcnc to fix the path/last program problem properly.
If you update linuxcnc and it stops working again this will be the fix for the handler file:
I would also suggest:
self.last_loaded_program = self.w.PREFS_.getpref('RecentPath_0', None, str,'BOOK_KEEPING')I would also suggest:
def all_homed(self, obj):
self.set_dro_homed(True)
if self.first_turnon is True:
self.first_turnon = False
if self.w.chk_reload_tool.isChecked():
STATUS.emit('update-machine-log', 'PreLoad Tool #{}: '.format(self.reload_tool), 'TIME')
command = "M61 Q{}".format(self.reload_tool)
ACTION.CALL_MDI(command)
if self.last_loaded_program is not None and self.w.chk_reload_program.isChecked():
STATUS.emit('update-machine-log', 'PreLoading NGC: ' + self.last_loaded_program, 'TIME')
ACTION.OPEN_PROGRAM(self.last_loaded_program)
self.w.filemanager.updateDirectoryView(self.last_loaded_program)
The following user(s) said Thank You: tommylight, Pro_El, hottabich
- hottabich
18 Apr 2020 04:33 #164395
by hottabich
the algorithm of the MDI Touchy module. Please tell me what is wrong with me.
I can not open QtTouchy to seeMDITouchy can work in Qtdragon for sure.
18 Apr 2020 04:58 #164401
wow you seem to find all the problems
I'm not sure what going on with qttouchy sample.
but to run the QtTouchyMDI command (assuming mditouchy is the widget name):
self.w.mditouchy.run_command()
18 Apr 2020 05:03 #164403
ahh did you move or did it ask to move the QtTouchy config?
It can't find the file: ../check_constraints.hal file
It' s in the sim/qtvcp_screens folder by default
Time to create page: 0.142 seconds
