Сustomization QTvcp
15 Apr 2020 03:38 #164036 by cmorley
Replied by cmorley on topic Сustomization QTvcp
If you have not homed then the button will say you have not homed.
NO_FORCE_HOMING =1 does not change that.
I found the problem with macroTab will push a fix soon.
15 Apr 2020 03:51 #164037 by cmorley
Just pushed a fix for the macroTab
15 Apr 2020 04:11 - 15 Apr 2020 04:22 #164038 by hottabich
Replied by hottabich on topic Сustomization QTvcp
I don’t know how, but in qtpyvcp, the Home All button at start is cheked and home X, Y, Z no.
Button All Home just should glow green. This does not mean that axis = 0.
Last edit: 15 Apr 2020 04:22 by hottabich.
15 Apr 2020 04:13 #164039 by cmorley
Yes, It's possible to do that but it's a lie. The machine is not homed.
15 Apr 2020 04:16 #164040 by cmorley
If you don't want to home then why not remove the button?
15 Apr 2020 04:26 #164041 by cmorley
It should not glow green - the machine is not homed.
NO_FORCE_HOMING = 1 does not mean linuxcnc starts already homed.
It means you are not required to home to run MDI or programs.
15 Apr 2020 04:27 #164042 by hottabich
The button indicates that the machine is ready for use! Yes the car is not homed!
15 Apr 2020 04:27 #164043 by cmorley
remove the button - it's useless if you are not going to home :)
15 Apr 2020 04:32 #164044 by cmorley
In the handler file try:
    def initialized__(self):
        self.set_dro_homed(True)
15 Apr 2020 04:37 #164045 by hottabich
Without homed, it is necessary when processing large files in case of emergency stop, but otherwise the traditional mode. Can macrotab be fixed?
Time to create page: 0.126 seconds
