Сustomization QTvcp
- Thank you received: 2175
The subroutine path is wrong in the ini.
remove ~ and add /home/jura
And why is it looking for probe_basic files there?
You are using QtVCP, not PyQtVCP.
qtdragon has a basic probe.
I'm still thinking this is related to language - as it works properly for me.
I'll see if I can remember how to change languages on my system and try again.
Chris
- Thank you received: 7471
Check what file it is trying to open on startup, it should be in the ini file as
open_file=xxxxxxx
qtvcp doesn't currently support preloading programs.
Did not know that, thank you for clarifying.
open_file=xxxxxxx
your log:
2020-04-17 09:54:48,769 - QtDesigner.QTVCP.QT_ACTION - INFO - Homing Joint: -1
2020-04-17 09:54:51,614 - QtDesigner.QTVCP.QT_ACTION - DEBUG - Load program /home/jura/linuxcnc/nc_files
2020-04-17 09:55:05,914 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Show
2020-04-17 09:55:08,740 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Button pressed is: &Yes
2020-04-17 09:55:08,741 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Hide
2020-04-17 09:55:08,742 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Value of pressed button: 16384
2020-04-17 09:55:08,845 - QTvcp.QTVCP.QT_MAKEPINS - INFO - Closing cleanup on: basicprobe
2020-04-17 09:55:08,846 - QTvcp.QTVCP.WIDGETS.BASIC_PROBE - DEBUG - Saving Basic Probe data to preference file.
Mine:
2020-04-17 11:57:56,248 - QtDesigner.QTVCP.QT_ACTION - INFO - Homing Joint: -1
2020-04-17 11:58:03,842 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Show
2020-04-17 11:58:14,314 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Hide
2020-04-17 11:58:14,314 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Saving FileDialog-geometry data from widget screen_options to file.
2020-04-17 11:58:14,456 - QtDesigner.QTVCP.QT_ACTION - DEBUG - Load program /home/chris/linuxcnc/nc_files/hazzy.ngc
2020-04-17 11:58:14,502 - QTvcp.QTVCP.WIDGETS.GCODE_GRAPHICS - DEBUG - load the display: /home/chris/linuxcnc/nc_files/hazzy.ngc
2020-04-17 12:03:12,493 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Show
2020-04-17 12:03:14,039 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Button pressed is: &Yes
2020-04-17 12:03:14,040 - QTvcp.QTVCP.WIDGETS.OVERLAY_WIDGET - DEBUG - Overlay - Hide
2020-04-17 12:03:14,040 - QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET - DEBUG - Value of pressed button: 16384
2020-04-17 12:03:14,139 - QTvcp.QTVCP.QT_MAKEPINS - INFO - Closing cleanup on: basicprobe
2020-04-17 12:03:14,140 - QTvcp.QTVCP.WIDGETS.BASIC_PROBE - DEBUG - Saving Basic Probe data to preference file.
Notice how your's loads the program before the overlay is shown or hidden and before the yes button is pressed.
Also your is missing the actual program name so it can't be actually loading a program I would think.
Chris
Found where the error is. How are you Chris with this file, load_dialog_action save in
examples and then there he searches for the error too.
Ahh yes I get it now in qtdragon it does preload a program!
I didn't have 'reload program' option selected that is why i didn't get the error.
if fname and not return_path:
if self.PREFS_:
self.PREFS_.putpref('last_file_path', fname, str, 'BOOK_KEEPING')
ACTION.OPEN_PROGRAM(fname)
STATUS.emit('update-machine-log', 'Loaded: ' + fname, 'TIME')
return fnameShould store the program name properly
Chris
All is good, i will continue to monitor from a distance.
