Сustomization QTvcp
- Thank you received: 2181
29 Apr 2020 02:14 #166050
Replied by cmorley on topic Сustomization QTvcp
add to INI, under [DISPLAY]
make sure this points to the folder with the macro:
MACRO=increment xinc yincmake sure this points to the folder with the macro:
PROGRAM_PREFIX = SOMEPLACE/macros/
- hottabich
- Thank you received: 96
29 Apr 2020 17:48 #166113
by hottabich
Replied by hottabich on topic Сustomization QTvcp
So in the attached INI file is this all there or am I misunderstanding something?
30 Apr 2020 05:23 #166187
What is the path to your macro?
I'd guess one of these needs adjustment.
PROGRAM_PREFIX = /home/jura/linuxcnc/nc_files
SUBROUTINE_PATH = ~/linuxcnc/nc_files/macros
- hottabich
30 Apr 2020 07:33 #166198
by hottabich
PROGRAM_PREFIX = / home / jura / linuxcnc / nc_files is set by default. Add PROGRAM_PREFIX = / home / jura / linuxcnc / nc_files / macros as well
SUBROUTINE_PATH = / home / jura / linuxcnc / nc_files / macros Qttouchy Macro does not work. The second option is SUBROUTINE_PATH = ~ / linuxcnc / nc_files / macros and
PROGRAM_PREFIX = ~ / linuxcnc / nc_files / macros is also not working. For the user, the best instruction is a working simulator from the beginning,
I think so. Thank you for the attention.
- hottabich
01 May 2020 15:59 #166335
by hottabich
Hello! Please tell me how functional is Probe Screen Widget in Qtdragon?
And what is the mechanism of his work. It does not respond to Probe Sim such as macros auto tool
zero.ngc. Thanks in advance.
01 May 2020 18:52 #166353
I personally have not used it or tested it with a probe.
QtDragon's creator,Jim, said he lightly tested it when I included it in linuxcnc.
I has a bunch of HAL pins that need to be connected for it to work.
- hottabich
02 May 2020 07:07 #166389
by hottabich
Qtvcp is a wonderful, very functional interface. As for me, only
SubCallButton.widget as in Qtpyvcp which makes it difficult to use macros, but everything else is great. I am heartily grateful for your work and your tolerance for me.
02 May 2020 07:49 - 02 May 2020 07:50 #166390
I know nothing about subcallButoon (really little of pyqtvcp for that matter) so can't comment on it.
You are welcolme for the help - we fized alot of bugs along the way!
Last edit: 02 May 2020 07:50 by cmorley.
- hottabich
02 May 2020 11:12 - 02 May 2020 11:14 #166399
by hottabich
Here is the SubCallButton code. If this can not be uploaded, delete my post.
Maybe based on it, you will come up with something for Qtvcp.
Last edit: 02 May 2020 11:14 by hottabich.
02 May 2020 22:41 #166440
Looks like a button that calls an Oword macro defined in Designer?
I could add similar ability to action buttons, though I think I'd have it read the macro name from the INI.
Chris
Chris
Time to create page: 0.127 seconds
