QtDragon on Debian Buster, some issues
  • keyboard
  • keyboard's Avatar Topic Author
  • Senior Member
  • Senior Member
14 Jun 2020 20:36 - 14 Jun 2020 20:38 #171668 by keyboard
QtDragon on Debian Buster, some issues was created by keyboard
Thanks to tommylights quick and easy install procedure, I have LINUXCNC - 2.9.0-pre0-2118-g0c8cdaaf1 running on Debian Buster.
I'm also using Qtdragon's excellent GUI running a Gantry. Now , I'm having a few issues as listed :
1. In Qtdragon, I can home all axes just fine , individually or together (home all). But , when one axis is homing and I press home for another axis, the first axis ignores the home/limit switch and crashes into the hard stop.
2.I can't get the probe screen activated.
3. Calibration on the Settings page does not bring up the window.
4. Not related to Qtdragon, but my XHC-HB04 wireless MPG does very slow Accel and Decel when moving an axis. How or where can I steepen the bell curve for axis movement ?
Thanks ,
File Name: qtdragon_xyz.ini
File Size:10 KB
File Name: qtdragon_xyz.hal
File Size:12 KB
Last edit: 14 Jun 2020 20:38 by keyboard.
14 Jun 2020 21:17 #171670 by cmorley
Replied by cmorley on topic QtDragon on Debian Buster, some issues
I just pushed the fix for the calibration button - it may take some time to run through buildbot before being able to update.
probe screen - did you connect all the HAL pins?
linuxcnc.org/docs/2.8/html/gui/qtdragon.html#_hal_pins
homing - I'll look into deeper
14 Jun 2020 21:23 #171671 by cmorley
You also haven't set the path for the basic probe subroutines.
( this sample isn't right for an installed version - you will need to find the path to this folder though)
[RS274NGC]
SUBROUTINE_PATH = ../../../../nc_files/probe/basic_probe/macros
15 Jun 2020 02:03 #171688 by bbsr_5a
Replied by bbsr_5a on topic QtDragon on Debian Buster, some issues
can you also post the xhc hb04 hal you use
it shoudt be in a postgui file not a machine File to run propper
  • keyboard
  • Senior Member
  • Senior Member
15 Jun 2020 17:11 #171775 by keyboard
Replied by keyboard on topic QtDragon on Debian Buster, some issues
Thanks Chris,
I will follow thru with the clues on both and get back.
  • keyboard
  • Senior Member
  • Senior Member
15 Jun 2020 17:13 #171776 by keyboard
Thanks for the reply bbsr_5a,
My xhc hb04 hal is in the main hal attached above. I will move it to postgui as you say and try it. All functions work, just that axis movement startup and stopping is very slow.
  • keyboard
  • Senior Member
  • Senior Member
06 Sep 2020 08:45 #181002 by keyboard
Hello,
Sorry, I've not got to testing for the probe and MPG. Meanwhile, got a potentiometer for Feed override working(Axis). But, here is my problem.
In, Qtdragon, when I change to MODE 1 for the MESA 7i76e in my .INI . The four pins don't change to Analog. They stay as I/O. (INI &HAL in first post above).
where as the same INI in AXIS does switch the pins over. Any help is welcome.
Thanks.
06 Sep 2020 09:43 - 06 Sep 2020 09:44 #181010 by Aciera
Replied by Aciera on topic QtDragon on Debian Buster, some issues
Have you set the smart-serial software mode correctly? (loadrt hm2_hm2_eth .... sserial_port_0="200xxxxx" or similar)
You would need to change
sserial_port_0=00xxxx
to
sserial_port_0=20xxxx
or
sserial_port_0=10xxxx
to get access to the 7I76E analog inputs
Last edit: 06 Sep 2020 09:44 by Aciera.
  • keyboard
  • Senior Member
  • Senior Member
06 Sep 2020 10:37 #181025 by keyboard
Hi Aciera,
Thanks for the response.
Yes, I have the same INI with sserial set to 1 , that works in AXIS and in HAL meter I see the ANALOG0 inputs. But, in QTdragon, it stays as a I/O.
And I have no errors.
06 Sep 2020 10:54 #181029 by Aciera
I apologize. I clearly need to read more carefully. :blush:
Time to create page: 0.657 seconds
