QtDragon on Debian Buster, some issues
06 Sep 2020 22:49 #181089 by cmorley
Replied by cmorley on topic QtDragon on Debian Buster, some issues
can you post both configs?
  • keyboard
  • keyboard's Avatar Topic Author
  • Senior Member
  • Senior Member
07 Sep 2020 16:45 #181179 by keyboard
Replied by keyboard on topic QtDragon on Debian Buster, some issues
Hi Chris,
Here the two configs. Hope you can find something, as I've run outta ideas.:(
07 Sep 2020 16:58 #181181 by cmorley
ok here is a stab in the dark... I see a difference in the HAL file for qtDragon
loadrt [HOSTMOT2](DRIVER) board_ip=[HOSTMOT2](IPADDRESS) config="num_encoders=[HOSTMOT2](ENCODERS)num_stepgens=[HOSTMOT2](STEPGENS)sserial_port_0=[HOSTMOT2](SSERIAL_PORT)"
There is no space between (STEPGENS) and sserial_port_0
  • keyboard
  • Senior Member
  • Senior Member
07 Sep 2020 19:28 #181198 by keyboard
Thanks Chris,
That space did it.
07 Sep 2020 21:25 #181203 by cmorley
excellent
  • keyboard
  • Senior Member
  • Senior Member
07 Sep 2020 22:23 - 07 Sep 2020 22:24 #181205 by keyboard
How do I update to get the changes?
I tried sudo apt-get update and upgrade , but didn't see any change in the calibration button function. (post # 171670)
Thanks.
Last edit: 07 Sep 2020 22:24 by keyboard.
07 Sep 2020 22:50 #181206 by cmorley
can you post a link to the post you are talking of? I can't seem to search post numbers.
if you got linuxcnc from buildbot then the update manager should pull in the newest.
07 Sep 2020 22:51 #181207 by cmorley
oh ok I see the post now.
how did you get linuxcnc?
  • keyboard
  • Senior Member
  • Senior Member
08 Sep 2020 10:05 - 08 Sep 2020 10:07 #181292 by keyboard
Thanks to tommylights quick and easy install procedure, I have LINUXCNC - 2.9.0-pre0-2118-g0c8cdaaf1 running on Debian Buster.
Last edit: 08 Sep 2020 10:07 by keyboard.
08 Sep 2020 12:27 #181306 by cmorley
So looks like that would be buildbot binary.
sudo apt-get update
sudo apt-get upgrade linuxcnc-uspace
should do it
Time to create page: 1.193 seconds
