qtdragon - new tool length after a manual tool change
- seebaer1976
- Thank you received: 5
26 Jul 2020 17:08 #175929
by seebaer1976
I don't know Mdi Touchy, is there a wiki or something about it?
Replied by seebaer1976 on topic qtdragon - new tool length after a manual tool change
Mdi Touchy allows you to use controlled macros. You can adjust the macro for your tasks.
- hottabich
- Thank you received: 96
26 Jul 2020 18:23 - 26 Jul 2020 19:47 #175945
by hottabich
Replied by hottabich on topic qtdragon - new tool length after a manual tool change
Look at the link for QtVcp widgets. Or just try it out in QtDragon!
Last edit: 26 Jul 2020 19:47 by hottabich.
- keyboard
- Thank you received: 4
25 Nov 2020 06:03 #190243
by keyboard
Hi seebaer1976
Im trying to implement this code for a toolsetter. I can get the Axes to move to toolchange position in the cycle. But after that what do I need to do to acknowledge that I have changed the tool and it can continue on to the Sensor to measure the tool. Thanks.
Replied by keyboard on topic qtdragon - new tool length after a manual tool change
I got in touch with peter dam ... from talla83.de. last year he wrote a script for dynamic tool measurement.
asked him if you can install it in qtdragon.
he has agreed and approved to use it.
here is a video on youtube:
and here the script:
Maybe it will help you.
it can perhaps be so integrated that it can be activated or deactivated under settings for those who do not need it.
markus
Hi seebaer1976
- seebaer1976
13 Dec 2020 14:31 #191865
by seebaer1976
normally a popup should open, which you confirm when you have changed the tool.
- seebaer1976
13 Dec 2020 19:21 #191892
by seebaer1976
How can I switch the probe screen from Basic Probe to Versa Probe?
would like to try Versa Probe, maybe I can do it with it.
best regards
seebaer1976
This is qtvcp's other probe screen.
best regards
seebaer1976
- hottabich
17 Dec 2020 06:26 #192228
by hottabich
Try it.
- ikkuh
- Thank you received: 48
11 Nov 2021 10:37 #226091
by ikkuh
Replied by ikkuh on topic qtdragon - new tool length after a manual tool change
Is this still a work in progress?
Using the latest version that is bundled with the BuildBot 2.9pre version (I update daily) there now is a pop-up screen but no movement to toolsensor or even toolheight measurement.
What am I doing wrong? I expected the behaviour to be like gmoccapy's toolmeasurement, the remapping of M6.
- Thank you received: 2181
13 Nov 2021 01:37 #226261
Replied by cmorley on topic qtdragon - new tool length after a manual tool change
Unless you added remap code to your configuration, then it will not probe at tool change.
I had done some work on a (hopefully) standard remap code to cover most requirements, but have not finished it.
but what ever code that was used with gmocccapy should be able to be adapted to qtdragon.
- harry4516
- Thank you received: 6
14 Nov 2021 22:25 #226516
by harry4516
Replied by harry4516 on topic qtdragon - new tool length after a manual tool change
I'm using qtdragon,
just implemented the files from Peter, talla83, video #29
and I can confirm that it works perfectly. Almost all setup was done with pncconf, then I added Peter's extensions.
During the first test the Z movement stopped with an error msg at the tool probe. This was fixed
by debouncing the tool probe.
When M6T1 is in the gcode, it moves to the tool change position, I change the tool and click the confirmation dialog. Then it moves over the tool sensor and slowly touches it. Then it moves z up to a secure position and continues.
- hottabich
15 Nov 2021 20:41 #226602
by hottabich
Hello Harry. Would you like to share your settings? Here's another option, can anyone try it: wiki.printnc.info/en/controllers/linuxcnc/tool-setter-no-probe
Time to create page: 0.201 seconds
