Learning to work with new QTVCP screens and handler
- Thank you received: 2181
13 Dec 2020 15:25 #191908
Replied by cmorley on topic Learning to work with new QTVCP screens and handler
The problem with MDI_CALL_WAIT is it blocks the ui while it waits - so keep it short as practical
- Pro_El
- Thank you received: 3
13 Dec 2020 17:34 #191924
by Pro_El
Replied by Pro_El on topic Learning to work with new QTVCP screens and handler
I find something i think is a problem with QTDragon build in Linuxcnc 2.9 with buster.
I run MDI Program and just i select with mouse from older commands in MDI and place cursor in MDI box it stops the MDI Execution. In Axis window it didn't stop and even if i execute second program in AXIS it finished first command and then go on with second command. I do not now if this is expected operation or not.
Thank you
Thank you
13 Dec 2020 18:59 #191928
What version of linuxcnc are you using?
Was the AXIS version that same?
I see in master 'stacking' MDI commands stops the previous ones.
It didn't do this in linuxcnc 2.7 and I haven't tested 2.8 yet.
Stopping an MDI command by cursoring into MDI line is probably a qtvcp bug - I'll look into it.
13 Dec 2020 19:45 #191929
Sorry i see you said you are using 2.9.
I'm investigating - i have found a bug in 2.8 that causes stacked MDi commands to not work properly. it could be the total problem after all.
13 Dec 2020 21:19 #191938
ok i think i got it fixed in 2.8 and master.
next time you update, let me know if it's fixed.
Chris
Chris
The following user(s) said Thank You: tommylight, hottabich
- hottabich
- Thank you received: 96
15 Dec 2020 00:47 #192030
by hottabich
Please make these changes, they work, you suggested them to me. Thank you.
Replied by hottabich on topic Learning to work with new QTVCP screens and handler
try in handlerfile
if flag:
if isinstance(receiver2, GCODE):
# if in manual or in readonly mode do our keybindings - otherwise
# send events to gcode widget
if STATUS.is_man_mode() == False or not receiver2.editor.isReadOnly():
if is_pressed:
receiver.keyPressEvent(event)Please Log in or Create an account to join the conversation.
15 Dec 2020 21:51 #192099
pushed to 2.8
Please make these changes, they work, you suggested them to me. Thank you.try in handlerfile if flag: if isinstance(receiver2, GCODE): # if in manual or in readonly mode do our keybindings - otherwise # send events to gcode widget if STATUS.is_man_mode() == False or not receiver2.editor.isReadOnly(): if is_pressed: receiver.keyPressEvent(event)
pushed to 2.8
- Pro_El
17 Dec 2020 17:31 #192282
by Pro_El
Sorry for late respond. Iv been able now to test your push in LCNC 2.9 with buster.
Now MDI is working like it should it finished the first command and even during execution of first command i enter second one the mdi finishes first and start second command. I think this is fixed now
You are great Chris
Bojan
You are great Chris
Bojan
17 Dec 2020 17:32 #192285
thank you for the report and update!
- Pro_El
18 Dec 2020 21:26 #192418
by Pro_El
Hello Chris. Perhaps is not a issue but missing future maybe in QTVCP widgets. GCodeGraphic did not show rotary A axis visual. I tested same ini on Axis and on QT dragon on A axis and it show visual rotation of 360 deg only on Axis screen. In QTDragon it's standing and only DRO is counting for A axis. I put A axis DRO my self. Is this a missing function of GCodeGraphic or i am missing something.
Thanks Chris
Thanks Chris
Time to create page: 0.563 seconds
