Learning to work with new QTVCP screens and handler
- Pro_El
- Thank you received: 3
14 Feb 2021 11:39 #198791
by Pro_El
Replied by Pro_El on topic Learning to work with new QTVCP screens and handler
I have new question
I am trying to show number on screen from code in py file
I connect lcdNumber widget to receive from slot1 in QTdesigner
I made def slot1(self): in py file to define it
What is the other commands so i can display some numbers in lcdNumber widget
The display numbers will be some float result in my code
I am open for suggestion for other approach to display numbers..
- Thank you received: 2181
14 Feb 2021 12:36 #198800
Replied by cmorley on topic Learning to work with new QTVCP screens and handler
QLCDNumber will only display integers.
Probably a plain QLabel will work for you.
Add a QLabel to the screen with designer - no slot or signal needed.
in the handler use code similar to this to update the label:
self.w.LABELNAME.setText('Value = {:.4f}'.format(self.myVariable))
The following user(s) said Thank You: Pro_El
- Pro_El
14 Feb 2021 19:37 - 14 Feb 2021 22:12 #198832
by Pro_El
Thanks is working good
I need some information where can i find list of all states i can use like state-on; state-off
I will need state for coolant-mist but i will want to now where can i find all the states i can use. For now i get error this signal not found even i can see coolant-mist in my HAl signal section
Example:
STATUS.connect('state-estop', self.say_estop)
STATUS.connect('state-on', self.on_state_on)
STATUS.connect('state-off', self.on_state_off)
STATUS.connect('jograte-changed', self.on_jograte_changed)
STATUS.connect('periodic', self.on_periodic)
Thanks Chris for best answers
Example:
Last edit: 14 Feb 2021 22:12 by Pro_El.
15 Feb 2021 01:39 #198891
This should have most of them:
linuxcnc.org/docs/2.8/html/gui/GStat.html
or look in lib/python/hal_glib.py
Chris
Chris
- persei8
- Thank you received: 133
26 Aug 2021 23:11 #218837
by persei8
Replied by persei8 on topic Learning to work with new QTVCP screens and handler
The documentation for GSTAT states that the status message jogincrement-changed returns a float. However, this is not the case. It returns a string which is whatever the jog increment widget is currently set to. To get around this, I do STATUS.get_jog_increment() which returns only the float value. Just thought I would mention it FYI. Regards.
Jim
Jim
27 Aug 2021 03:53 #218855
Hey Jim it actually should send both (from hal_glib)
self.emit('jogincrement-changed', self.current_jog_distance, self.current_jog_distance_text)
I wonder if your code (or mine) uses lambda to cut off the float?
- persei8
27 Aug 2021 13:39 #218906
by persei8
You're right, that is exactly what happened. I should have clued in when it complained about the wrong number of arguments. Still, maybe the documentation could mention this to avoid future confusion?
Jim
Jim
