FileManager extensions
5 years 11 months ago - 5 years 11 months ago #190025 by hottabich
Replied by hottabich on topic FileManager extensions
If you write in the handler like this
##################### # GENERAL FUNCTIONS # ##################### def load_code(self, fname): if fname is None: return if fname.endswith(".ngc") or fname.endswith(".py") or fname.endswith(".tap"):
then when selected, all files will be loaded ngc, tap. In the interface phillc54 must be removed USB copy file.
Last edit: 5 years 11 months ago by hottabich.
5 years 11 months ago #190026 by cmorley
Replied by cmorley on topic FileManager extensions
that function has changed quite a bit recently.
It now checks for extension type in INI
[FILTER] PROGRAM_EXTENSION = .ngc,.nc,.tap G-Code File (*.ngc,*.nc,*.tap) PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python
In master the function looks like this:
def load_code(self, fname): if fname is None: return filename, file_extension = os.path.splitext(fname) if not fname.endswith(".html"): if not (INFO.program_extension_valid(fname)): self.add_status("Unknown or invalid filename extension {}".format(file_extension)) return self.w.cmb_gcode_history.addItem(fname) self.w.cmb_gcode_history.setCurrentIndex(self.w.cmb_gcode_history.count() - 1) ACTION.OPEN_PROGRAM(fname) self.add_status("Loaded program file : {}".format(fname)) self.w.main_tab_widget.setCurrentIndex(TAB_MAIN) self.w.filemanager.recordBookKeeping() # adjust ending to check for related setup files fname = filename+'.html' if os.path.exists(fname): self.w.web_view.load(QtCore.QUrl.fromLocalFile(fname)) self.add_status("Loaded HTML file : {}".format(fname)) else: self.w.web_view.setHtml(self.html) return else: try: self.w.web_view.load(QtCore.QUrl.fromLocalFile(fname)) self.add_status("Loaded HTML file : {}".format(fname)) self.w.main_tab_widget.setCurrentIndex(TAB_SETUP) self.w.stackedWidget.setCurrentIndex(0) self.w.btn_setup.setChecked(True) self.w.jogging_frame.hide() except Exception as e: print("Error loading HTML file : {}".format(e))
5 years 11 months ago #190028 by cmorley
hottabich wrote: Thanks, it works! Another question before the attached file loaded well, and now the code is loading
and the picture remains the same.
The very first line
'Q Linuxcnc.ngc'
is not legal code
Chris
5 years 11 months ago #190030 by cmorley
this is in the next release of 2.8
def load_code(self, fname): if fname is None: return filename, file_extension = os.path.splitext(fname) if not fname.endswith(".html"): if not (INFO.program_extension_valid(fname)): self.add_status("Unknown or invalid filename extension {}".format(file_extension)) return self.w.cmb_gcode_history.addItem(fname) self.w.cmb_gcode_history.setCurrentIndex(self.w.cmb_gcode_history.count() - 1) ACTION.OPEN_PROGRAM(fname) self.add_status("Loaded program file : {}".format(fname)) self.w.main_tab_widget.setCurrentIndex(TAB_MAIN) elif fname.endswith(".html"): self.web_view.load(QtCore.QUrl.fromLocalFile(fname)) self.add_status("Loaded HTML file : {}".format(fname)) self.w.main_tab_widget.setCurrentIndex(TAB_SETUP) self.w.btn_setup.setChecked(True) else: self.add_status("Unknown or invalid filename")
5 years 11 months ago #190031 by hottabich
The very first line
'Q Linuxcnc.ngc'
is not legal code
Chris
Thanks! But it worked before. But that's not a problem. I'll put all your corrections into my interfaces. Thank you very much!
Time to create page: 3.223 seconds
