Save file sort parameters between sessions
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
31 Oct 2021 20:38 #224793 by rodw
What version of Qt are you using (or what version of linux).
It works for me with mint 20 qt 5.12.8
I pulled the latest version of master to get your changes. So I should be running QTplasmac  v1.215.110 2021 Oct 27I was testing on a sim on my Chromebook. I'll try on real hardware when I get a month in the next day or so as the weekend is over!
31 Oct 2021 21:15 #224798 by snowgoer540
Replied by snowgoer540 on topic Save file sort parameters between sessions
I was a bit confused by your earlier post, you said it worked but then asked if it could stay between sessions?  That would indicate to me it didn’t work?  Or did I miss something?
31 Oct 2021 21:45 #224806 by cmorley
Replied by cmorley on topic Save file sort parameters between sessions
Can you post the output from the terminal start and close of qtplasmac?
There might be a clue in there. Qsettings (the basis of this) was added in qt 5.9.x so should function.
  • rodw
  • Platinum Member
  • Platinum Member
31 Oct 2021 22:17 #224814 by rodw
File Name: qtplasmac_run.txt
File Size:4 KB
Dump attached. I wonder if its a permissions issue?Where is it saved?This is RIP so I assumed its under ~/linuxcnc-dev somewhereMaybe QT saves elsewhere.
01 Nov 2021 00:18 #224820 by snowgoer540
See attached.
  • rodw
  • Platinum Member
  • Platinum Member
01 Nov 2021 02:31 #224822 by rodw
hmm, I wonder if there are some clues in /home/plasma/qtvcp.log
I will check it tonight
01 Nov 2021 03:44 #224826 by cmorley
The file should be recorded in (substitute your home folder name for chris):
/home/chris/.config/QtVcp/
01 Nov 2021 04:11 #224832 by cmorley
It seems that no matter what, on each restart (of LCNC), the following are always "None":
sect = self.SETTINGS_.value('sortIndicatorSection')
order = self.SETTINGS_.value('sortIndicatorOrder')
Although they are being assigned a value when they are getting set during the cleanup.
Also, if I hard code them (3 and 1 for date and descending), then it does work. So it's something with storing or recalling the setting.
could you add:
self.SETTINGS_.sync()
to file_manager in the _hal_cleanup function after the line:
self.SETTINGS_.setValue('sortIndicatorOrder', h.sortIndicatorOrder())
And see if that helps?
01 Nov 2021 07:02 #224846 by phillc54
Replied by phillc54 on topic Save file sort parameters between sessions
It seems to be working for me with master updated this afternoon.
01 Nov 2021 07:05 #224847 by cmorley
excellent. I found some time to test on an older system. It seems newer versions of qt must call synch() automatically, so i added the command to cover older systems.
Hopefully it works for everyone now.
Time to create page: 1.155 seconds
