Save file sort parameters between sessions
01 Nov 2021 07:07 #224848 by Tesremos
Replied by Tesremos on topic Save file sort parameters between sessions
is there any way to push this to stretch?
01 Nov 2021 07:11 #224850 by phillc54
Replied by phillc54 on topic Save file sort parameters between sessions
Thanks Chris, I am on Qt 5.11.3
01 Nov 2021 07:17 #224851 by cmorley
Replied by cmorley on topic Save file sort parameters between sessions
Do you mean linuxcnc 2.8?
01 Nov 2021 07:43 #224853 by Tesremos
nope. master - stretch. no update since may.
01 Nov 2021 08:47 - 01 Nov 2021 08:48 #224857 by snowgoer540
Replied by snowgoer540 on topic Save file sort parameters between sessions
excellent. I found some time to test on an older system. It seems newer versions of qt must call synch() automatically, so i added the command to cover older systems.
Hopefully it works for everyone now.
Had a few minutes to try before heading to work this morning, happy to report it's now working well after the latest commits.
Thanks Chris!
Last edit: 01 Nov 2021 08:48 by snowgoer540.
01 Nov 2021 17:28 #224896 by cmorley
You would need to edit stuff manually. IIRC stretch is too old for master now.
01 Nov 2021 23:34 #224934 by Tesremos
Can you point me at what, and where?
02 Nov 2021 05:25 #224952 by cmorley
Can you run linuxcnc from a terminal and then post the output?
I winder if you are still using python2 or not. There are 4 files to change but I gotta figure out where they are.
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Nov 2021 09:08 #224964 by rodw
Well I got as far as building linuxcnc today on my machine but thats as far as I got.. There is always tomorrow.
02 Nov 2021 10:16 #224971 by snowgoer540
I take your post to mean that the process of building linuxcnc took you awhile.  Just was wondering what your process is there?  Pulling and compiling the latest updates usually takes < 1 minute total depending how much compiling is needed.  I think last night was < 3 min.
If you're re-cloning the project each time, you don't need to do that...
Time to create page: 0.160 seconds
