- Thank you received: 31
QtDragon, Linuxcnc 2.9pre, and Debian 12 (bookworm)
4 years 2 months ago - 4 years 2 months ago #250627
by Roguish
QtDragon, Linuxcnc 2.9pre, and Debian 12 (bookworm) was created by Roguish
Well, I might have go ahead of it all, but I upgraded from debian 10 to 12, and installed Linuxcnc via synaptic and the debian 12 repo.
Linuxcnc startup fine. tried an axis sim first. no problems.
Then tried my qtDragon config.......NO luck. Not a linuxcnc problem. It's sure seems to be a qtvcp and/or qtdesigner problem(s).
I run from a terminal window with all debugging on. see the file below for the terminal output.
As qtdragon loads, it errors (see the 'dragon startup error - initial' image).
If I select 'abort', it totally aborts.
If I select 'retry' one more widget appears, the throws the same error (see the 'dragon startup error - after couple of retrys' image)
I am out of ideas.
any thoughts would be greatly appreciated.
PS. qtdesigner does not startup either. see the 3rd image.....
I am out of ideas.
Last edit: 4 years 2 months ago by Roguish.
4 years 2 months ago #250628
Replied by cmorley on topic QtDragon, Linuxcnc 2.9pre, and Debian 12 (bookworm)
yes a PYQT library changed it's arguments from floats to integers.
I don't have a Debian 12 system so have not identified every one.
Eyecon ran into this and I think he manually fixed it - I'm not sure he gave a patch.
If you put int() around the complaining arguments that should be a quick fix.
Chris
Chris
The following user(s) said Thank You: Roguish
4 years 2 months ago - 4 years 2 months ago #250629
by Roguish
Replied by Roguish on topic QtDragon, Linuxcnc 2.9pre, and Debian 12 (bookworm)
Chris. thanks
I think I found Eyecon's post forum.linuxcnc.org/qtvcp/46412-python-fu...-linuxcnc-2-9#247616
He says there it is a python 3.10 (and probably greater) problem, and 3.9 is no problem.
Am I reading that correctly?
If so, how could I go back to 3.9?
just checked. i'm on 3.10.6 currently
4 years 2 months ago #250631
not easily I think. he probably moved to an older distro.
4 years 2 months ago #250633
by Roguish
Well, seems to be a problem for the not too distant future, that really needs to be sorted out.....soon.
What da ya think???
What da ya think???
4 years 2 months ago #250634
Ya I should be able to fix things just from your error messages - might take a couple tries.
Time to create page: 0.324 seconds
