QtDragon, Linuxcnc 2.9pre, and Debian 12 (bookworm)
4 years 2 months ago - 4 years 2 months ago #250651 by Roguish
Chris,
I edited those 3 files that you changed.
and even changed the extension on the matching .pyc files.
still no luck.
terminal output is attached.....
could this be because I have a customized qtdragon ???
Last edit: 4 years 2 months ago by Roguish.
4 years 2 months ago #250653 by cmorley
change these lines:
elif self._shape == 1:
x = int(self.width() - self._diameter - self._right_edge_offset)
y = int(0 + self._top_edge_offset)
The following user(s) said Thank You: Roguish
4 years 2 months ago #250654 by cmorley
keep the original indenting though
4 years 2 months ago #250655 by cmorley
in simple_widget.py I should say
4 years 2 months ago #250657 by Roguish
Chris.
got it.
WORKS.
THANKS.
i will post again if there are any more oops.
please put that in the src files......
pere says minimum 12 hours for changes to show in the repository files.... we'll see.
4 years 2 months ago #250658 by cmorley
Excellent!
Thanks for doing some leg work and prodding.
12 hours wow. I hope that can be improved in the future.
I'll push the remaining fix soon.
Chris
Time to create page: 0.390 seconds
