QtDragon, Linuxcnc 2.9pre, and Debian 12 (bookworm)
4 years 1 month ago #251918 by Roguish
Chris,
well, error on exit of qtdragon.
see the image attached.
more of nuisance than a problem, I think.
4 years 1 month ago #251960 by cmorley
Looks like your screen code and qtdragon's has diverged... the line that errored is not in the latest code.
The following user(s) said Thank You: Roguish
4 years 1 month ago #251963 by Roguish
If I could run QtDesigner,maybe I could fix it.....
What is causing the error???
4 years 1 month ago - 4 years 1 month ago #251965 by cmorley
in the handler file: line 258 'self.probe.closing_cleanup__()
There is no such function in versa probe
Last edit: 4 years 1 month ago by cmorley.
4 years 1 month ago #252038 by Roguish
I'm creating a VM right now in VMWare.
starting with debian 11.5 and doing a full upgrade.
then I'll install Linuxcnc. and hopefully it'll all work.
Then I can see what's going on.
I'll bring in my .ui file from the mill, and see if it opens in qtdesigner....
stay tuned....
4 years 1 month ago #252084 by Roguish
Chris,
qtvcp_plugins.py  definitely has problems....
my new debian 12 VM with 2.9pre proves it.  see the images.
one image shows starting qtdesigner without the link to qtvcp_plugins.py.   designer works....
the other image show starting qtdesigner with the link to qtvcp_plugins.py.    designer fails, with that error of float to int
please fix this....
I can definitely help with testing..  let me know.
It needs to get resolved, sooner or later.   sooner far better than later.
Time to create page: 0.285 seconds
