QtDragon, Linuxcnc 2.9pre, and Debian 12 (bookworm)
4 years 2 months ago - 4 years 2 months ago #250635 by Roguish
I am open and anxious to help any way I can......
like lots of testing....
please just ask away...!!!
Last edit: 4 years 2 months ago by Roguish.
4 years 2 months ago #250640 by cmorley
I just pushed the problems I found with drawing.
It comes with other updates mainly to qtdragon_hd - hopefully I haven't missed something there.
If you are compiling you can pull and test now. Buildbot usually takes quite awhile.
What kernel # are you using with bookworm?
The following user(s) said Thank You: Roguish
4 years 2 months ago - 4 years 2 months ago #250641 by Roguish
thanks
Linux 4.19.0-9-rt-amd64
I have installed lcnc via the debian 12 repository. no clue where it gets its .deb's
what files did you have to modify?
if you post them here, could I use them? if yes, how???
OK,  i see them in src files.....3 files.  python.
if I download and replace my existing ones with those, shouldn't it work?   python being a non-compiled coding and all.....
OK, again.....  I edited the existing files identical to your edits in src.
but still get the same errors....
what gives?
4 years 2 months ago #250646 by tommylight
Strange, Debian 12 BookWorm should have 5.nn kernels, not 4.19.
Give PhillC's script a try, it always worked for me on Debian and Mint for installing QT stuff:
forum.linuxcnc.org/qtvcp/38414-installing-qtvcp
4 years 2 months ago #250649 by Roguish
I changed it with grub_customizer....
lots left over from earlier distros
4 years 2 months ago #250650 by cmorley
apparently sometimes the 5.x isn't as good.
If 4.x works...
Time to create page: 0.063 seconds
