NCGGUI and QtDragon
3 years 8 months ago #264385 by cmorley
Replied by cmorley on topic NCGGUI and QtDragon
QtDragon should remember the size and location of the window automatically without using -g - if it doesn't, that sounds like a preference file problem or a customization problem.
-m or -f should work too
I do believe the other error is fixed already - but I'll check. yep it's fixed. I guess your version is behind the source.
The following user(s) said Thank You: Roguish
3 years 8 months ago #264387 by Roguish
Replied by Roguish on topic NCGGUI and QtDragon
Preference file? what should be in that?
I see under [SCREEN_OPTIONS] there is mainwindow_geometry = xxxxxx
What should that be?
If I delete that specific line, will it regenerate? or be overridden?
3 years 8 months ago #264389 by cmorley
If you hand edit the preference file - the screen must not be running or it will be overridden when the screen closes.
If you remove the line, it will regenerate.
I believe the line represents x,y,width,height
3 years 8 months ago #264392 by persei8
Replied by persei8 on topic NCGGUI and QtDragon
Right. There should be a = sign between them. The INI is right, I just said it wrong.
3 years 8 months ago #264396 by Roguish
Chris,
ok I think i see what's up.
this is the last out of the pref file. I shut down dragon first, then my ferror panel.
if the numbers are as you mention, it's writing the info from the ferror panel..not the main dragon panel.
next time I run I will shut down the ferror panel before the main dragon, and see what happens....
[SCREEN_OPTIONS]
mainwindow_geometry = 1664 67 248 440
3 years 8 months ago #264397 by Roguish
I am currently using a deb from Seb's buildbot2 repository. date:
linuxcnc-uspace_2.10.0~pre0.486.g7abb824bf_amd64.deb
are you and Jim (persei8) pushing to 2.9 or 2.10 or where/???
Time to create page: 0.207 seconds
