- Thank you received: 2181
Chris,
ok I think i see what's up.
this is the last out of the pref file. I shut down dragon first, then my ferror panel.
if the numbers are as you mention, it's writing the info from the ferror panel..not the main dragon panel.
next time I run I will shut down the ferror panel before the main dragon, and see what happens....
[SCREEN_OPTIONS]
mainwindow_geometry = 1664 67 248 440
Jim works in a private repo.I am currently using a deb from Seb's buildbot2 repository. date:
linuxcnc-uspace_2.10.0~pre0.486.g7abb824bf_amd64.deb
are you and Jim (persei8) pushing to 2.9 or 2.10 or where/???
