Hello,
that looks very appealing.
Thank you very much for the effort you put in for me.
If the question were, does it make sense to actually install the controllers? That makes it easier to find the right values, but the whole process is only rarely needed once. Once you've found the value, it's actually done.
In this regard, it would be good to know what other users think about it.
I'm actually of the opinion that user interfaces should be kept slim if possible, as long as it doesn't impair usability.
For my part, I wouldn't have a problem if I had a section in the INI that contains these values, as long as it survives the updates.
I just looked at the aspect ratio again.
My camera has 1600x1200 pixels, which corresponds to a ratio of 4:3. This means that the image is slightly wider than it is tall (exactly a factor of 1.3333).
As I understand it, that's what it would mean for a square display. The image is either compressed (oval) when using all pixels in X or so that the circle remains round, pixels on the right and left have to be cut off.
Kind regards, Frank.
