Camera configuration
2 years 9 months ago #291642 by cmorley
Replied by cmorley on topic Camera configuration
Yes I see your point - it's cluttered.
I could just add the scale settings to the preference file. Editing that is fairly easy a bit of trial and error.
Maybe that is best for 2.9 and see what other users ask for.
2 years 9 months ago #291702 by cmorley
Ok I pushed another change that looks in the preference file for:
[CUSTOM_FORM_ENTRIES]
Camview xscale = 100
Camview yscale = 100
These are in percent.
You can only edit the preference file when qtdragon is _not_ running.
When it is next loaded it will use the new settings.
Chris
2 years 9 months ago #291731 by wusel0464
Replied by wusel0464 on topic Camera configuration
Hello,
Thanks, just tried to give it a try.
Disabled QTDragon.ui and dealers in my home directory and added the section to the INI.
But no matter what I pass as a value, nothing changes in the image.
Before changing Linuxcnc closed and then restarted.
All other files have the status of today's update.
Does the section have to be in a certain position in the INI?
Kind regards, Frank.
2 years 9 months ago #291734 by cmorley
The entries go in the preference file - qtdragon.pref in your config folder.
2 years 9 months ago #291735 by wusel0464
Hello,
Sorry, found it, it's in the QTDragon preferences.
Works as expected, thank you!
Since I don't actually play around with this file, I didn't even have it on my screen.
2 years 9 months ago #291737 by cmorley
Excellent. Thanks for the feedback.
Time to create page: 0.368 seconds
