Inconsistent values from Versaprobe
- zieluch
- Thank you received: 6
20 Dec 2024 15:57 - 20 Dec 2024 16:01 #317045
by zieluch
Replied by zieluch on topic Inconsistent values from Versaprobe
I am running into similar problem but maybe I found root cause. Need to do some more testing but please check below and share the result.
Can you please do the following:
cheers
Michal
- M6 overwrite routine macro - On the tool change remove all the G43 command except one at the end after tool measurement., in my case it was m6 g43 on semi manual change
- start linuxcnc
- go to tool table and set in column Z =0 for probe and two random tools which you later test on example T1 and T2.
- load probe m6 t99
- go to object and measure it.
- change to t1: m6 t1 with tool measurement
- check if offset is correct if so try another tool t2
- if T2 is ok now check other tools (one which has Z <>0 value in the tool table)
cheers
Michal
Last edit: 20 Dec 2024 16:01 by zieluch.
The following user(s) said Thank You: gardenweazel
- gardenweazel
- Thank you received: 10
20 Dec 2024 16:38 #317047
by gardenweazel
Replied by gardenweazel on topic Inconsistent values from Versaprobe
I'll test this later this afternoon.
Thank you so kindly for assisting.
- gardenweazel
22 Dec 2024 00:29 #317118
by gardenweazel
I'm sorry but this does not work for me as described.
Few have chimed in(thanks for those that have), does anyone have VersaProbe working as expected?
- zieluch
22 Dec 2024 11:42 #317137
by zieluch
Can you share your ini file and tool change macro ?
- gardenweazel
23 Dec 2024 17:39 #317211
by gardenweazel
Sure.
The attached qt_auto_probe_tool.ngc file has been altered however, I can use the same file that comes with the master
and there are no differences in the outcome.
In the ini file the reference to this line was added by me per another thread here .
# This is the MAX Z travel to my spindle chuck without a tool.
Z_REF = -183.97
Of particular interest, is that after I add my probe tool Z offset, it gets removed somewhere during the procedure.
It was: T99 P99 D+2.000000 Z0 ;3D Probe
It's now: T99 P99 D+2.000000 ;3D Probe
Thanks for your help, can you share your probe NGC file?
Z_REF = -183.97
- MaHa
- Thank you received: 241
23 Dec 2024 19:38 #317220
by MaHa
Replied by MaHa on topic Inconsistent values from Versaprobe
Can you try to replace this 2 lines from
to
#<zworkoffset> = [#5063 + #[5203 + #5220 * 20] + #5213 * #5210]
#<tool_length> = [#<zworkoffset> - #<_ini[VERSA_TOOLSETTER]Z_REF>]to
#<zworkoffset> = [#5063 + #[5203 + [#5220 * 20]]]
#<tool_length> = ABS[ABS[#<_ini[VERSA_TOOLSETTER]Z_REF>] - #<zworkoffset>]
- MaHa
23 Dec 2024 22:14 #317236
by MaHa
I just realized, there is something missing. You need to know the distance from #<_ini[VERSA_TOOLSETTER]Z_REF> (-183.97) to table surface. This must be added to toollength. Then you can work with table as base.
I think the toollength probing result you get now, is wrong by exactly this value.
- gardenweazel
23 Dec 2024 22:20 #317237
by gardenweazel
I will measure this from Z0 to table top but, what's the VAR that I add it to?
- MaHa
23 Dec 2024 22:36 #317238
by MaHa
In the ini, under Versaprobe there is Diameter. Maybe you can add below HEIGHT = nnn and use it as #<_ini[VERSA_TOOLSETTER]HEIGHT>
It could look like this:
#<tool_length> = ABS[ABS[#<_ini[VERSA_TOOLSETTER]Z_REF>] - #<zworkoffset> + #<_ini[VERSA_TOOLSETTER]HEIGHT>]
- gardenweazel
24 Dec 2024 01:10 #317254
by gardenweazel
I tried what you recommended, this time after the back-off touch, nothing happened and the spindle just sat there with no movement. Although no error.
For some crazy reason I also lost control of my WHB04B-4 MPG. Incredibly annoying!
As an FYI in versaprobe routine there is a BLOCKHEIGHT and PROBEHEIGHT which is what I suspect that you're eluding to here.
I'd like t o hear from ANYONE who's is successfully using VersaProbe successfully using the master.
Realistically, I simply want an error free manual tool change with minimal error margins.
Thanks @MaHa!
Thanks @MaHa!
Time to create page: 0.158 seconds
