Rods "Spaceship" Scratch built Plasma Cutter build
9 years 9 months ago #85305 by rodw
Well, it seems people are following along. I had a request overnight to explains some of my HAL code. It just goes to show once you understand something, you gloss over the detail where the hard bits live. This was not meant to be a tutorial, but for the other beginners like me here goes:
You should know by now that loadrt loads a HAL module into your setup
Once you load a module, you usually need to put it in the thread you want to use it in with addf
So you usually need a loadrt and an addf statement before you can use it.
Some HAL modules need you to set a parameter to a given value. you use setp to do that.
With some modules (like or.2), you may use them in multiple places so you need to add a count parameter. I've already got 3 or2 statements in use so I added one more here
loadrt or2 count=4
Real computers count starting from 0. Just ask any assembly language or C programmer. Once you start counting from 0, a lot of things become a lot easier. So HAL numbers each of the statements as or2.0, or2.1, or2.2, or2.3. As this is the 4th or i've added, I am using or2.3.
But more importantly, because I am using a 7i76e, I need to load the mesa driver hm2_eth.
loadrt hm2_eth board_ip="10.10.10.10" config="firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=2xxxx"
pncconf makes a valiant effort at making this statement but you probably need to tell it the ip address its installed on. If you read the documentation, you need to place the driver in mode 2. This is the bit that does that sserial_port_0=2xxxx. I found this example on the forum here so I copied it. Don't ask me what the other statements do. :)
I'm using master branch to get the gantry joint axis feature and I think this has meant some code has changed as the axis module now has axis.x, axis.y etc instead of axis.0, axis.1 etc. So lets look at the next snippet which just sets up some defaults.
setp axis.x.jog-vel-mode 0 net x-jog-counter <= hm2_7i76e.0.7i76.0.0.enc0.count net x-jog-counter => axis.x.jog-counts
The jog-vel-mode parameter can be either 0 or 1. I've set it to 0 so that a given jog step completes. Using a 1 here means that motion stops as soon as you stop turning the wheel.
The next 2 lines read the 7i76e enc0.count and sends it to axis X so that HAL knows which axis to move. You can fold this up onto one line but I broke it up for ease of reading (so try to do this yourself as a training exercise. I did.)
So lets deal with the scale selection. To conserve pins most examples use the mux4 hal component and I realised I left these lines out of my example to load it (now corrected)
loadrt mux4 count=1 addf mux4.0 servo-thread
This conserves pins once you can work out how to wire in a binary coded switch :)
these next lines do 3 things. They load the value of the input pins (I'm using 21 & 22) used by the selector switch into a variable I created but along the way, it also loads the value of these pins into an or2 statement. They also send the pin values to our mux4 component inputs.
net mux-in1 or2.3.in0 <= hm2_7i76e.0.7i76.0.0.input-22 => mux4.0.sel0 net mux-in2 or2.3.in1 <= hm2_7i76e.0.7i76.0.0.input-21 => mux4.0.sel1
I think you could break these up onto more lines to make it easier to read so try doing that as a learning exercise.
Before an axis can be jogged, it needs to be enabled using x-jog-enable and that is the purpose of my or.2 output. It will be true (1) whenever a scale is selected with the switch and 0 when the switch is in the off position
net x-jog-enable <= or2.3.out net x-jog-enable => axis.x.jog-enable
Now we need to set the scale according to the position table I documented in the previous post using setp.
# jog scale for each switch position in mm setp mux4.0.in0 0.0 setp mux4.0.in1 1.0 setp mux4.0.in2 0.1 setp mux4.0.in3 0.01
You will need to alter the scale values if your machine is using inches.
And now finally tell axis.x which scale to use
net x-jog-scale mux4.0.out => axis.x.jog-scale
So there you have it. A working single axis MPG handwheel using the Mesa ENC0 input and a scale selector switch.
I think Andy said somewhere once that this stuff is hard becasue it really is hard but I hope that this explains whats going on.
The following user(s) said Thank You: Clive S, gerold, Masiwood123
9 years 9 months ago - 9 years 9 months ago #85378 by rodw
No eBay APP ID and/or Cert ID defined in Kunena configurationOne of the things I wanted to do is to get some warning lights enabled as a traffic light system. After a fruitless afternoon yesterday, Todd wrote the code out for me on this thread
forum.linuxcnc.org/24-hal-components/321...green?start=10#85375
Of course, it is never as simple as it seems to implement a code example in Hal.
This is what Todd gave me
loadrt and2 count=2 loadrt xor2 count=1 loadrt siggen num_chan=1 addf and2.0 servo-thread addf and2.1 servo-thread addf xor2.0 servo-thread addf siggen.0.update servo-thread setp siggen.0.frequency 2 #Yellow Light net yellow-in1 <= halui.machine.is-on => and2.0.in0 net yellow-in2 <= halui.program.is-idle => and2.0.in1 net yellow-out <= and2.0.out net yellow-out => hm2_7i76e.0.7i76.0.0.output-01 #Green Light net green-in1 <= halui.program.is-running => xor2.0.in0 net green-in2 <= halui.program.is-paused => and2.1.in1 net flash <= siggen.0.clock => and2.1.in0 net green-flash <= and2.1.out => xor2.0.in1 net green-on <= xor2.0.out => hm2_7i76e.0.7i76.0.0.output-02 #Red Light net red-on <= halui.estop.is-activated => hm2_7i76e.0.7i76.0.0.output-00
And becasue I wanted to also keep the functionality of the run/step hold/resume buttons from this example
forum.linuxcnc.org/47-hal-examples/13201...-hold-resume-buttons
This is what I came up with
loadrt xor2 count=1 loadrt siggen num_chan=1 loadrt and2 count=6 addf and2.0 servo-thread addf and2.1 servo-thread addf and2.2 servo-thread addf and2.3 servo-thread addf and2.4 servo-thread addf and2.5 servo-thread addf xor2.0 servo-thread # External Program Pause/Resume and Run/Step Buttons # Pause/Resume Section net pause-resume-btn and2.0.in0 and2.1.in0 <= hm2_7i76e.0.7i76.0.0.input-02-not net pause-on toggle2nist.0.is-on <= and2.0.in1 <= and2.3.in1 <= and2.5.in1 <= halui.program.is-paused net run-on and2.1.in1 <= xor2.0.in0 <= halui.program.is-running net pause-sig or2.0.in0 <= and2.0.out net resume-sig or2.0.in1 <= and2.1.out net toggle-ok toggle.0.in <= or2.0.out net togglesig toggle2nist.0.in <= toggle.0.out net toggleon halui.program.pause <= toggle2nist.0.on net toggleoff halui.program.resume <= toggle2nist.0.off # Run/Step Section net run-step-btn and2.2.in0 and2.3.in0 <= hm2_7i76e.0.7i76.0.0.input-01 net idle-on and2.2.in1 <= and2.4.in1 <= halui.program.is-idle # net pause.on and2.3.in1 <= halui.program.is-paused # and2.3.in1 was added in the net pause-on statement in Pause/Resume Section net run-sig halui.mode.auto halui.program.run <= and2.2.out net step-sig halui.program.step <= and2.3.out net estop-out estop-latch.0.fault-out # --- RED, GREEN AMBER WARNING LIGHTS --- #Yellow Light net yellow-in1 <= halui.machine.is-on => and2.4.in0 net idle-on <= halui.program.is-idle => and2.4.in1 net yellow-out <= and2.4.out net yellow-out => hm2_7i76e.0.7i76.0.0.output-01 #Green Light net flash <= siggen.0.clock => and2.5.in0 net green-flash <= and2.5.out => xor2.0.in1 net green-on <= xor2.0.out => hm2_7i76e.0.7i76.0.0.output-02 #Red Light net estop-out hm2_7i76e.0.7i76.0.0.output-00
And here it is in action
Ultimately, I had in mind to add a stack light on top of the gantry so the machine status can be seen at a glance across the room. Something like this one (when I can find one with LED's in it/
image missing http://i.ebayimg.com/images/g/lMQAAOSw8w1YAqxg/s-l1600.jpg
Last edit: 9 years 9 months ago by rodw.
The following user(s) said Thank You: snoozer77, hairy
9 years 9 months ago #85391 by Clive S
Rod
This looks like it has LEDs in it according the the tittle. www.aliexpress.com/item/24V-Industrial-R...0010508.4.119.OZ1S8p
9 years 9 months ago #85394 by rodw
Clive s wrote: Rod
Thanks Clive. There seems to be a few around on eBay as well. I even found one on Aliexpress for $10 with free freight even.
9 years 9 months ago #85451 by rodw
I ended up ordering this Stack light
www.aliexpress.com/snapshot/0.html?order...roductId=32718843984
The same seller had one without the mast extension for $10 but I thought the mast extension might be handy.
Anyway, I've finally set up my THC component so its fully functional in bench testing. I had some trouble becasue I forgot that I'd set the frequency on the THCAD board to 1/32. Eventually I remembered and once I reworked it, it is spot on accurate.
I added a 24 volt LED light to the Spindle output relay and tested it went on with gcode M3 and off with M4
I added a switch to the THC ArcOk input pin to +24v so I could test it
I grabbed a 100k potentiometer and took a +5v wire from one of the 7i76e stepper drivers and ran it though the pot to the IN+ input on the thcad. I ran a ground wire from the stepper -5v to the IN- port on the THCAD.. Turning the pot varied the voltage from about 2.5v to 5v.
Then I just used Hal configuration window in axis to check the thc pins to make sure that they were doing the right thing. thc.volts at the console tracked the mutimeter on the THCAD IN terminals nicely.
Here is the HAL setup
# --- TURN TORCH ON --- net spindle-on motion.spindle-on => hm2_7i76e.0.7i76.0.0.output-04 # --- TOUCH OFF --- net torch-probe motion.probe-input <= hm2_7i76e.0.7i76.0.0.input-09-not # --- THC - TORCH HEIGHT CONTROLLER --- # thc calibration data 0v = 122.9 kHz (122900), 10v = 925.7 kHz (925700) # so at 10V, 925700 = 122900 + (80280 * 10) # but we are using 1/32 divider on THC board # 1/32 input 0v = 3840.625, 10v = 28928.125 # 1/32 at 10v 28928.125 = 3840.625 + 2508.75 * 10 # 1/32 scale = 1/2508.75 = 0.000398605 setp thc.vel-scale 0.000398605 setp thc.scale-offset 3840.625 setp thc.velocity-tol 1.0 setp thc.voltage-tol 1.0 #This might need to be increased setp thc.correction-vel 0.00001 setp hm2_7i76e.0.encoder.00.scale -1 setp hm2_7i76e.0.encoder.00.counter-mode 1 net thc-encoder-vel hm2_7i76e.0.encoder.00.velocity => thc.encoder-vel net thc-current-vel thc.current-vel <= motion.current-vel net thc-requested-vel thc.requested-vel <= motion.requested-vel net spindle-on => thc.torch-on # starts the motion when the plasma arc has transfered to the work net start-motion-input thc.arc-ok <= motion.digital-in-00 <= hm2_7i76e.0.7i76.0.0.input-10 #enable THC just for TESTING net thc-enable thc.enable <= hm2_7i76e.0.7i76.0.0.input-31-not
The last 2 lines were just to test that the signal was being enabled and just uses a spare input pin that has a TRUE output.
The maths in the comments is pretty self explanatory. I referenced these 2 links to build this config
The THC manual page linuxcnc.org/docs/html/man/man9/thc.9.html
Big John's Hal example gnipsel.com/shop/plasma/files/plasma.hal
I decided to start from the manual page to see how well I understood hal and basically used Johns to check my input at the end.
I'm pretty sure PCW said it was best to use the THCAD 1/32 frequency divider. If anybody thinks I should do otherwise, please let me know.
9 years 9 months ago #85515 by rodw
Well, I'm a bit stumped here tonight and its late (well not by Tommy's standards) so I'm going to sleep on it. Because I've only got a gantry (Y & Z), I did not have the stepper motors on the right stepgens and tonight I decided to see if I could fix it and start to set up for Joint Axis on the X axis as it won't be long before I have all axes working.. I plugged the steppers into their correct controllers. I swapped the X axis over to the Y axis in the hal and ini files and its working perfectly. I had the machine configured as XYZ and now I'e set it up as a XXYZ with the axies in bold being the ones I've got active now (except the Z is not working)
The Z on the other hand is not behaving. When jogging, it issues a very faint click and a tiny bit of movement (that you can feel but can't really see the movement. I wondered if I had the limit switches misconfigured and it was sitting on a limit switch but this is not the case and they check out OK. They trigger an error correctly.
I'll double check the wiring in the morning in case I got that wrong between the 7i76e and the stepper controller. I moved all of the signals in HAL and INI files from Joint 1 to Joint 3. I've previously checked the stepper driver is OK.
I'm sure I'll get to the bottom of it but if anyone has some ideas on where to look, please let me know.
Time to create page: 0.431 seconds
