rodw wrote: So this got me thinking about redirecting the THCAD frequency output to an Arduino to do the signal processing before sending the processed minimum voltage to LCNC.
If you can write Arduino code to do the job then you can write a custom HAL component to do the same job.
PCW wrote: Note that you cannot use the THCAD for fast conversions (if you sample at 40 KHz you will get only about 5 bits of resolution)
Its conceivable to use a Arduinos A-D and capture the minimum value, though I do suspect you would need better torch power to make this of any use as the combination of ripple, hash from the plasmas switching power supply and probalems getting enough common mode rejection with the required input circuitry would mean you get a very high noise to signal ratio
(I suspect you have the fine sandpaper out when a chain saw is in order)
tommylight wrote: Do not take my word for it, but that does not look very good. Usable, most probably.
I gave my brother a Fujitsu Siemens Celsius workstation that makes some nice narrow spikes in the rangege of under 3000, now i have to find a way to take it back nicely. It is an 8 Xeon processor, 16GB ram, 2 RAID contoller monster, although several years old.
Did you get the laser cut parts?
