A bits been happening. I had a visit from a CNC zone member who tracked me down through a mate to check out my progress.
I've purchased the steel for the table on Saturday morning. I borrowed the work ute to collect it and then cut it down before I bought it home.
image missing http://i210.photobucket.com/albums/bb270/rodweb/Mobile%20Uploads/2017-02/20170218_102053_zpsbusbygvu.jpg
Stacked up in a corner of the garage.
image missing http://i210.photobucket.com/albums/bb270/rodweb/Mobile%20Uploads/2017-02/20170219_101851_zpsajtx3tzv.jpg
And I have one of the gantry axes running at last! Even if it is lying on its side.
image missing http://i210.photobucket.com/albums/bb270/rodweb/Mobile%20Uploads/2017-02/20170219_101833_zpsumkaslaa.jpg
I had a lot of trouble calibrating the travel accurately. When I did the last rack and pinion, I just calculated the steps per mm and plugged it in for it to work perfectly. This rack and pinion was sold as a 1.25 module set and the actual readings were quite a way out so I did some calibration against a 1.0 m steel rule. Anyway, I got it working in the end. I sent it up and down the gantry for 20 metres using relatives moves in gcode
And the error was 0.02 mm
image missing http://i210.photobucket.com/albums/bb270/rodweb/Mobile%20Uploads/2017-02/20170219_101826_zpsz9iewsqi.jpg
I think that at 0.001 mm per metre, that is about as good as it gets. I did not use the dial indicator when I calibrated it, so I might look at it again based on the findings above.
I wasted hours this morning becasue of my inexperience with Linux. Norbert had fixed a Gmocappy bug that I found and reported earlier in this thread sop I wanted to pull it down and install it for testing. Anyway, things went wrong and cncnoob came to the rescue so after taking ownership of my linuxcnc-dev folder that root had somehow stolen, I did a "make clean" followed by a "make" and it was all back on track.
I'm quite keen to try dewey's development branches with axis offsets and a couple of other features on git hub becasue it is fixing some of the unforseen issues the developers missed that needed to be fixed following merging of the joint axis code into master.
I have a few things to round up before I can tackle the table and the next couple of weekends are pretty full so progress will slow somewhat for a while. I need to have everything here to mount some casters to it as once its welded together, I won't be able to move it without them. As I plan to build it right where my wife parks her car, I gotta be careful! Anyway, at least I am still chipping away.
