Rods "Spaceship" Scratch built Plasma Cutter build
9 years 8 months ago - 9 years 8 months ago #88248 by rodw
Sorry, thats 20x microsteps for 4000 ppr.
Last edit: 9 years 8 months ago by rodw.
9 years 8 months ago #88249 by racedirector
Here ya go
That is a lot of microsteps, what drivers are you using?
9 years 8 months ago #88250 by racedirector
With a zillion decimal points:
9 years 8 months ago - 9 years 8 months ago #88253 by rodw
Bruce, thanks, I just checked my hal. I am running 261 mm per rev and the measured rack distance per rev on the pinion is about 5mm over what it should be (should be 23 * 1.5 * pi) so go figure....
The outer diameter of the pinion is exactly 1.3" so I'm wondering if it isn't an imperial pitch but it did not match up with a gear calculator.
Yes, when I first started, I pushed the Mesa card as fast as I could and then increased the microstepping up to 25x before I got following errors then backed off a bit. I then reduced the step timing from 2500 to 1500 but never tried to see if I could go further. Any way they are not missing a beat at 18 metres per minute.
I'm using Longs motor DM542a steppers. There are a lot of other 542's out there but from what I've seen, these are a better class of controller.
9 years 8 months ago #88255 by racedirector
Rod, send me your email address - brucen at bsww dot com dot au, and I'll send you the excel file so you can play with everything yourself :)
9 years 8 months ago #88303 by rodw
racedirector wrote: Rod, send me your email address - brucen at bsww dot com dot au, and I'll send you the excel file so you can play with everything yourself :)
Email sent. Thanks Bruce.
Time to create page: 0.418 seconds
