- Thank you received: 2349
The THCAD10 has a maximum continuous input voltage rating of 500VDC so 12.5V or 500V will read as full scale but willIf you cut at 45 amps at 200 volt = 12.5 Volt (Mesa max is 10Volt in, smoke out of garage :dry: )
The other parameter we discovered in testing is that the THCAD board has a rise time of 5 ms which in the sim equates to a lowpass of 70 Hz (I'm just quoting what Dewey told me after looking at some plots I did for him as I don't really understand that).
PCW wrote: The THCADs rise time is less then 0.5 ms. A 5 ms risetime would be detrimental to loop tuning. Of course any post direct data
filtering will affect the loop bandwidth.
tecno wrote: Possible to use a simple voltage divider with suitable resistors as a pre divider?
