docwelch wrote: Rod and/or John,
Back on page 32 of this thread, John posted a schematic of his wiring. I noticed that he uses a relay to power/depower the limit switches and estop. What is the reason behind this? Based on the fact you both have working machines, I'm pretty sure there's a reason for doing it this way but I haven't been able to see the benefit(s).
Thanks,
Steven
islander261 wrote: docwelch
Rod
I know you don't want to hear this again. If just removing the protection diode fixes your probing indicator you have a ground fault in your "floating" power supply circuit some place. This isn't ideal but just goes to show how good the 7i76E is.
Good Luck
