Rods "Spaceship" Scratch built Plasma Cutter build
6 years 2 weeks ago #186268 by tommylight
rodw wrote: Gee, the were just getting to the moon when I was a kid
tommylight wrote: O ring.
Wasn't it a rubber part that failed on your table too Tommy?
Yup.
6 years 1 week ago #187148 by rodw
So I am pleased to say after about 4 years in the making, I finally have the spaceship in a final position and off its casters. We also routed all the air and power down from overhead so there is nothing on the ground to trip over.
We gave it another torture test while cutting on Friday and the boost feature has solved the motors eventually overheating and the motors are much cooler to the touch. But I had an over temperature fault on the top most driver in the control panel. I think it is my fault for placing the drives where the old ones were which meant that drive was being heated by the ones below it which is not per the layout in the Lam manual. More adjustments!
But I had wired the Lam driver fault output to joint.L.amp-fault-in. This basically triggered an estop event and therefore I was unable to recover and continue to cut the file in a complex nest.
Is there an alternative method I could use to halt motion yet still recover?
The following user(s) said Thank You: pinder
6 years 1 week ago #187174 by Mike_Eitel
Dont know if it has a functionaliy spindle.M.at−speed
Should stop (next? move) with a wait
Mike
6 years 1 week ago #187175 by rodw
Mike_Eitel wrote: Dont know if it has a functionaliy spindle.M.at−speed
Mike
Thats not a bad idea. I think Plasmac uses that signal but I could and2 it. I'll check it out. Thanks Mike!
5 years 11 months ago - 5 years 11 months ago #189430 by rodw
My laser pointer died. I think it was becasue it fell off with the torch and pulled the wires out of the back. This time I used a different one with a 16mm barrel
I made a new bracket for the laser and clamped it in after slitting the part and adding a clamping bolt.
During the week, We sold a towbar for the new Isuzu Dmax which was the first available for the latest model. We would have sold the first one off the production line from this particular company.
They had drawn the part incorrectly. Luckily our customer took it in his stride and just drilled a couple of holes through the chassis!
Man, I nearly did it myself on this part as I had based my drawing on an earlier part with the bolt holes in position but I drew it up on the wrong side of the part. Lucky I saw it in time!
Just goes to show how easy it is to stuff something up even with 3D cad design.
Last edit: 5 years 11 months ago by rodw.
The following user(s) said Thank You: tommylight, Himarc3D, pinder
5 years 11 months ago #189445 by tommylight
Please do accept my sincere condolences ! :)
Time to create page: 6.072 seconds
