- Thank you received: 7491
2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
5 years 1 month ago #221909
Replied by tommylight on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
As per request, here are the close ups of the reduction and the "invisible" reduction!
Most of the troubles with reductions are caused by the lack of that aluminium L profile, i have another 30CM of it left so i am saving as much as i can. Had found nearly 4 meters of it last year together with both of the profiles in pictures by accident and found out they were ordered by accident also, so i can not find it anymore, literally the guy had no idea he has that stuff in his shop till i sent him a picture of a small part that a friend of mine found in his yard, probably have to make an offer he cant refuse to push him to get me more!
The following user(s) said Thank You: Joco
- Joco
- Thank you received: 327
5 years 1 month ago #221912
by Joco
Replied by Joco on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Awesome - that confirms some thinking and looks very similar to some of my hack up sketches. Is that 6mm or 10mm angle aluminium? I don't have any so had been planning to use the 6mm thick flat bar I have to weld up my own angle shapes. Buying is not very attractive as I don't need much and there are minmum lengths I would need to get. Heck if that is 10mm from flexibility point of view I would be better off get some 10mm or 12mm flat bar and either welding or bolting it into place.
5 years 1 month ago #221914
It is a 48X88X8mm L shaped alu, a bit of an overkill but i do like overkill.
I also use 50X10 flat alu bar for the idlers on the Y axis, and this i can order again from Austria through a company i worked for, roughly 16 Euro/M, so i am happy with it.
Since we are here, by some dumb luck i did find M3x20 hex head screws, M3 heat inserts, and some days ago also found some cr@ppy M3x24 and M3x18! :) Spent over 3 months hunting those, talking about wasting perfectly good time...
- Joco
5 years 1 month ago #221918
by Joco
Cool - great to know. my 65x6mm bar on my way smaller machine should be plenty then. Just as well I haven't packed away the TIG yet, looks like I'm going to be needing it again.
What you using the M3's for? I'm mostly using, M4 (only for the linear rails), M5 and M6.
- Joco
5 years 1 month ago - 5 years 1 month ago #221921
by Joco
Question re gantry squaring. I don’t recall seeing this procedure explained but if there is a link that would be great. If not, interested in understanding the procedure and tools needed to correctly square the gantry to the Y axis of the machine. This should help in initial setup of the gantry and in fine tuning the homing switch trigger points.
thanks - James.
thanks - James.
Last edit: 5 years 1 month ago by Joco. Reason: Lack of preview function is driving way more after post edits. Grrrrr!
5 years 1 month ago #221927
M3 are used in every 3D printer on the planet, while here are non existent.
6mm is more than enough for a reduction if the gantry does not weight in to much.
Squaring is easy since 2.8, no need to move switches or adjust screws or.... nothing really, all you need is a plate/plank/blanket/big piece of paper to mark the set points with a sharpie, at 0.0, 0.1000, 2000.1000, 2000.0, then measure diagonally between two of those points and other two of those points.
Be aware that when measuring if using a tape measure it is very important to have the tape always on the same side of the set points, messing that alone can skew about 1-2mm. Values above are example, use what your machine can handle. Also never edit both Y offset values in the .ini file at the same time.
Now, say the measured values came back 8mm longer on one side, that will roughly be 4mm out on one side so use that in the .ini for offset.
The following user(s) said Thank You: Joco, snowgoer540
Time to create page: 4.521 seconds
