2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
  • Moderator
  • Moderator
4 years 2 weeks ago #253994 by tommylight
Just a short update, all 3 machines from the latest batch are finished, configured, tested and fire tested.
The only things still missing are the side panels and cable chains, still printing those :)
For a longer update, head over here:
forum.linuxcnc.org/show-your-stuff/32784...t-15?start=30#253992
4 years 2 weeks ago #254058 by rodw
I will read the posts you have mentioned. Rods' one is a big one, 70+ page.
Sorry about that!
I was actually surprised how easy the 1600mm  linear rails were to align. We had them joined up with a fake gantry when we welded up the table to check for fit and it all came together easy...
  • Moderator
  • Moderator
3 years 7 months ago #266749 by tommylight
The following user(s) said Thank You: billykid, snowgoer540, my1987toyota
3 years 7 months ago #266796 by my1987toyota
Tommy is the screen supposed to momentarily turn off when the machine strikes an arc ?
  • Moderator
  • Moderator
3 years 7 months ago #266821 by tommylight
Some of them do blank, some do not, this one does that because of the cable, it is the best i could fund here but still not good.
The plasma source is a high voltage/ high frequency pilot arc one, so makes huge amounts of interference.
I have a video where this plasma blanks a monitor on the other shop at every start using that same type of cable. That is 7 meters far and through metal clading!
3 years 7 months ago #266881 by Joco
Still printing cable chains??   Is there a model that you use that you share a link to or is it something of yours that is home grown?
Time to create page: 0.701 seconds
