2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
17 Mar 2023 11:23 #266902 by tommylight
Yes i do, but this time from PETG, the first batch from PLA warped and was rendered useless, meaning my shop gets to over 55 degree celcius in the summer! :)
The model i got from thingiverse, there are plenty, but some have issues with motion. These ones seem good, so i can find the link and post it here if you want me to.
The last bought ones cost an arm and a leg at roughly 70 euro per meter, citing pandemics and other BS!
Now i have to do some color coordination .... :)
  • Moderator
  • Moderator
17 Mar 2023 23:00 #266949 by tommylight
Here is the link to the drag chain
www.thingiverse.com/thing:3292033/files
Spent 10 minutes on google, does not find it at all, duckduckgo found it on first try!
The hate level for google is consistently rising! :)
The following user(s) said Thank You: Joco
  • Moderator
  • Moderator
26 Mar 2023 18:05 #267544 by tommylight
Here is a video of one of those machines pushed quite far, cutting at 12m/m!
Missed the material 0 though... The guy on the video is the owner of the shop and machine now, he learns stuff quite quickly.
The following user(s) said Thank You: billykid, my1987toyota
19 Apr 2023 16:58 #269427 by my1987toyota
What dimensional tolerances could someone normally expect with one of these machines?
  • Moderator
  • Moderator
19 Apr 2023 17:36 #269434 by tommylight
With a bit of test cutting, 0.2mm is quite attainable.
To many variables at play, air, nozzle wear, speed, material, etc.
Most times with 2 to 3 tries i get 0.1mm for small parts, but i never take that for granted.
Realistically, 0.5mm is always OK to aim for, on decorations it does not matter, and these always, always do decorations.
The following user(s) said Thank You: my1987toyota
  • Moderator
  • Moderator
19 Apr 2023 17:37 #269435 by tommylight
19 Apr 2023 17:49 #269438 by my1987toyota
that is definitely moving. Nice
30 Apr 2023 19:12 #270327 by Joco
Yup i did think about doing just that, but i have not belt to do both sides for now.
And the ringing was there because the belts were very loose, now they are tight as a drum, so no ringing, and no vibration.
Tommy - in the middle of working out belt tensions and measuring real travel v”s requested travel to tune step scale.  Can you give anymore guidance on what “tight as a drum” means? Eg no more than X mm’s droop with a 1kg weight?
Also on your pulleys did you loctite them on to help avoid any shift?
thanks - J
  • Moderator
  • Moderator
30 Apr 2023 22:34 #270344 by tommylight
Exactly, at 3.3 meters i had it so it does sag 10mm with 5kg load.
That was more of a "feeling" thing than any math or static calculation.
Be aware that my belts were of very good quality made by PowGe, China, 15mm wide HTD3 type, stainless steel reinforced, so they can withstand huge amounts of tension.
30 Apr 2023 23:43 #270353 by Joco
Thanks. I'm running the same 15mm PowGe steel reinforced belts. My runs are much shorter. 1.3m on X and ~650-700mm on Y.
Time to create page: 0.863 seconds
