- Other Stuff
- Show Your Stuff
- 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
- Thank you received: 7488
26 Jul 2022 23:11 #248378
Replied by tommylight on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
regarding HiWin, i forgot to mention that all my machines are fully bolt on, so they can be adjusted, and that makes them not a good choice for me.
Otherwise, if the frame is rigid, HiWin can be used, of course.
I have used and still use HiWin and THK and NSK linear railrs, they are an abomination when you look at how much dynamic load they can handle, supported round ones can handle less than 1/10 of that, i have new THK 35mm ones with long carriages that can do 17900KG of dynamic load!
As for dust, i had the worst case where the rails were up and full of dust and water and they are still good, but also had a single case where one HiWin HGR25/HGH25 locked after a week of use.
There is also a huge difference in tolerances, linear ones will lock even from plasma fine dust if it gets in, round ones will continue working like nothing happened.
- pit34
- Thank you received: 4
28 Jul 2022 20:04 #248581
by pit34
Replied by pit34 on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Thanks, Tommy, for this feedback.
I have not yet chosen between welded or bolted frame, so I still can adapt my frame to rail. But yours say make me afraid about this dust vulnerability.
I have found some dustproof accessories on Hiwin site . Wipers go from small to heavy, and a metal scraper can be added to protect against sharp dust. There is top and bottom sealing too. But as the displacement performance decrease as the wiping performance increase, it is difficult to choose the best ratio between both. I think I would have to test some and adapt if necessary.
As you have some experience with stepper motors' power and capabilities, do you think the "high" displacement resistance added by those wipers could cause some visible issues on cut quality ?
I keep using these damn Hiwin rails while my very dusty workshop may not simply allow it...
28 Jul 2022 20:44 #248585
I saw your drawing on the other topic, that will do just fine, for many, many years.
Do not use extra wipers and scrapers, except the standard ones that come with the HGH carriages, they add a lot of friction.
Also a single HGR15 is more than enough for the X axis/gantry if you make the Z axis lite enough. Two for the Y axis, HGR15 also more than enough.
Make the moving parts as lite as possible, notice on my machine everything on the gantry and Z axis is aluminium, except the rails.
- pit34
29 Jul 2022 21:25 #248653
by pit34
Ok. Thanks Tommy for those advices, again.
It is not sure yet, all is still in thinking state, but as I maybe will add a wood router tool on the head in addition of the plasma tool, I think I will go with HGR20 ones. Just to not close a door.
12 Oct 2022 01:31 #253994
Just a short update, all 3 machines from the latest batch are finished, configured, tested and fire tested.
The only things still missing are the side panels and cable chains, still printing those
For a longer update, head over here:
forum.linuxcnc.org/show-your-stuff/32784...t-15?start=30#253992
- Thank you received: 4149
13 Oct 2022 05:47 #254058
I was actually surprised how easy the 1600mm linear rails were to align. We had them joined up with a fake gantry when we welded up the table to check for fit and it all came together easy...
Replied by rodw on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Sorry about that!I will read the posts you have mentioned. Rods' one is a big one, 70+ page.
15 Mar 2023 12:56 #266749
The following user(s) said Thank You: billykid, snowgoer540, my1987toyota
- my1987toyota
- Thank you received: 448
16 Mar 2023 00:37 #266796
by my1987toyota
Replied by my1987toyota on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Tommy is the screen supposed to momentarily turn off when the machine strikes an arc ?
16 Mar 2023 11:00 #266821
Some of them do blank, some do not, this one does that because of the cable, it is the best i could fund here but still not good.
The plasma source is a high voltage/ high frequency pilot arc one, so makes huge amounts of interference.
I have a video where this plasma blanks a monitor on the other shop at every start using that same type of cable. That is 7 meters far and through metal clading!
- Joco
- Thank you received: 327
17 Mar 2023 03:40 #266881
by Joco
Replied by Joco on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Still printing cable chains?? Is there a model that you use that you share a link to or is it something of yours that is home grown?Just a short update, all 3 machines from the latest batch are finished, configured, tested and fire tested.
- Other Stuff
- Show Your Stuff
Time to create page: 0.216 seconds
